Old 04-05-2014, 08:38 AM   #1
tie down
I am getting a cedar creek cottage. Seeing it is designed as a "destination" trailer I would think there would be an ability to tie this thing down but......no joy, I have not been able to get any info not from factory or dealer.
Any experience here?
tarpumn is offline   Reply With Quote
Old 04-05-2014, 08:47 AM   #2
Ford Idaho's Avatar
Pull the axles and use the spring mounts as tie down points.
Old 04-05-2014, 10:11 AM   #3
Can't because insurance dictates that trailer needs to remain movable. Was thinking along the lines of bolts in concrete pad and some type of quick connect/release to frame.
Frame seems to be nicely enclosed which makes access difficult.
Old 04-05-2014, 08:53 PM   #4
Former Full Timer
Duckogram's Avatar
Tie down straps or chains are required here in FL.
Here is a link to some typical applications.
The strap hook goes on the I Beam so you don't have to drill.
There is a bolt on hook as well but I can't find a link right now
Tie Down Supplies
Most folks with destination units detach the hitch so they
have 2 parking spots. Gotta put that golf cart somewhere.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 04-12-2014, 07:24 AM   #5
poofam's Avatar
Look for small Beam clamps to secure to frame then rig something up off them to the ground. We have a 2014 40crs on a permanent site blocked (love it) tires still on for insurance reasons. Did you get duel pain windows and heat pump ? We are very impressed with the performance of both was in the mid 40s few weeks ago and never used the furnace.
Sent from my HTCONE using Forest River Forums mobile app
poofam is offline   Reply With Quote
Old 04-12-2014, 08:23 AM   #6
Ford Idaho's Avatar
https://www.google.com/#q=Vertical+Plate+Lifting+Clamps
Once in place and pull pressure applied very hard to pull loose.
Old 04-12-2014, 11:08 AM   #7
poofam's Avatar
Ford and Idaho that is what we call a plate dog @ work to pick up sheets of steel. A small beam clamp is like a vice that you crank to tighten. We use 2 and 5 ton at work but you can get smaller ones. Won't find them at Lowe's or HD but Grainger has them . Don't know how to post pics yet otherwise I would show you. Don't know why poster would want to tie it down that good, I'm in hurricane country (nc coast) and will pull out if one comes.
Old 04-12-2014, 11:12 AM   #8
poofam's Avatar
Beam Clamps - Rigging Hardware - RiggingWarehouse.com this is what it looks like
Old 04-18-2014, 08:37 PM   #9
after dkscussion with local rv service dealer we decided to have tie downs at both sides of two bar and two over axles. Easy, strong and cheap.
Old 04-18-2014, 08:44 PM   #10
Ford Idaho's Avatar
What will you use to anchor them to the ground?
