Old 05-28-2016, 01:17 PM   #1
Tire issue
I have maybe 200 miles on my new 33RL. Washing it today and to my surprise I'm missing a big section of thread of one of the tires. Has anyone else had success with warranty to replace all 4 tires. I simply don't trust the other 3 at this point.
ID:	109343   Click image for larger version
Doug Currie is offline   Reply With Quote
Old 05-28-2016, 03:18 PM   #2
Tire issue
Replaced with the same tire brand doesn't sound good. See if can get a credit towards a decent tire like the carlisle radial trail rh.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-28-2016, 05:41 PM   #3
If these are junk the next batch won't be any better, Take what you can get, if anything and buy a set of Maxxis tires. Nothing else will do
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 05-28-2016, 08:32 PM   #4
Certified Curmudgeon
I suggest you contact your dealer and have them contact FR. If that does not work step 2 is to contact FR warranty yourself. Be calm, rational yet firm. I have full confidence that FR will take care of this for you.
My 2nd suggestion is that you install a TPMS. So when they change your rubber, make sure they install metal valve stems.
Safe travels,
Ducky
Mike Dropped
Old 05-29-2016, 09:33 PM   #5
Commercial Member
Be sure to record the full DOT serial and file a complaint with NHTSA. It seems possible that the tire importers are playing gamed with the regulations and might be keeping the quantity of tires below the threshold when they have to inform NHTSA of the adjustment rate.
Can't be completely sure but it looks like contamination between the top belt and tread rubber. I would think this is not a one off. Also do not think the failure was caused by anything the owner might have done.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
Tireman9 is offline   Reply With Quote
Old 05-30-2016, 09:47 AM   #6
Double King tires wear out doubly fast. Seriously though, just work with the dealer/FR to make it right, but I doubt they'll spring for a better brand. Maxxis, Goodyear 614s and Sailuns are much better tires if you can get them in your size.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 05-30-2016, 09:59 AM   #7
DDC
DDC's Avatar
X2 Reporting it should be mandatory, if there is no reports they are considered safe and you know the answer to that.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 05-30-2016, 10:15 AM   #8
Witch Doctor's Avatar
Well I'm getting new Maxxis 8008 put on in the AM. Had Marathons always liked them, last trip a belt went and and I had to get it replaced, this trip to Mayberry Rally a chunk came out in the wear strip and the metal I guess radial strip punched it out, so I'm trying a new brand..,.
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-31-2016, 06:53 PM   #9
steelpony5555's Avatar
If you still have ST tires on that big of a 5er you are just asking for problems... if you are under 14K lbs gross then go with an E rated truck tire..over they look at G rated tires like Goodyear G614's....ST tires are not good for that kind of weight and the speeds of todays highways...
From Central Texas
2014 Cedar Creek Silverback 29IK
2010 Dodge Laramie 3500 Dually
My Steelpony....2007 HD Ultra Classic...done up in a memorial to the 343 firefighters who died 9/11
Never Ever Forget....yes I was a Volunteer FF for 20 years........
steelpony5555 is offline   Reply With Quote
Old 05-31-2016, 07:04 PM   #10
So, did you get Maxxis or Hercules? One post said Maxxis and another said Hercules.
Old 05-31-2016, 07:12 PM   #11
crunchman12001's Avatar
Cut your losses and buy some Maxxis 8008's, highly recommended here. Why have the dealer reinstall the same china bombs?
2015 F-250 FX4
Old 05-31-2016, 07:14 PM   #12
I have never ever posted I was getting Hercules tires, Take your meds...
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-31-2016, 07:22 PM   #13
Sorry, that was Bob Caldwell asking about where the Hercules were made.
Old 06-04-2016, 08:37 AM   #14
Well forest river came trough and offered me 50% back on 5 new tires. I choose Carlisle and are already installed including spare. Just waiting my reimbursement cheque from forest river. Awesome service from both my dealer and forest river.
Old 06-04-2016, 10:15 AM   #15
Commercial Member
Doug
Glad FR took action. If you recorded the tire DOT serial it also would be good to file complaint with NHTSA on the "tread delamination" tire failure. Many times this type of failure simply does not make it into the NHTSA database and with out sufficient numbers there will never be any action from NHTSA.
If you do not have the DOT then it may not be of value as that is a key bit of information DOT needs. Everyone should have a record of the DOT of all their tires written down. This will help you know if you are involved if there is ever a tire recall in the future.
tire
