06-09-2019, 03:43 PM
Tires
Currently we have the Goodyear G614 RST LT235/85R16 on our 38' 5th wheel. Will need to replace by next year. What are you all using?
06-09-2019, 03:47 PM
Oh, we run 80 psi and seems to be fine in the Texas heat.
06-09-2019, 04:04 PM
The Sailun S637 is the ONLY tire equal to the G614s, and it cost about 25% less
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
06-09-2019, 04:38 PM
Sometime around 2015 or late 2014 Cedar Creek switch from Goodyear tires to Westlake tires. I have been running the same set since I purchase my trailer new in May of 2015. My tires are Westlake ST235/85R/16 load range G 129/125 L. The tires are aired up to 110PSI for a load of 4080 LBS each.
I believe other owners of the newer Cedar Creeks have been using the same tires and I have not seen or heard of very many if any tire failures on Cedar Creeks.
I plan on replacing them sometime late this year or early next spring since they will be 4 years old by date code in Aug.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
06-09-2019, 05:13 PM
G614's are 110 psi tires. Not as much load capacity at 80 psi. They are good tires, buy 'em again.
I upped to H rated Goodyear G114's. 400 more lbs capacity per tire at 125 psi.
FROG AR-0019-242
08-13-2019, 03:13 PM
Buying tires rated more than required, just bounces the crap out of your rig. Buy tires rated slightly above axle capacity.
But buy G614, Saliun, or Hercules tires.
08-19-2019, 02:41 PM
For our RV, I'm a Goodyear G614 fan. When we bought our 37MBH about 2 months ago, 2 days later the Westlakes were removed and replaced with 614s. Past 5er I had too many blowouts and issues with China Bombs and, knock on wood, none since switching to Goodyear 614s. Greatest peace of mind ever.
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
08-29-2019, 08:42 PM
G114 215/75R17.5 LR-H on 41' Silverback
2017 Ram 3500 DRW, 2018 41' Cedar Creek Silverback 37 FLK, 2005 30' Sandpiper
08-29-2019, 09:22 PM
Brake is on left
We just opted for the Provider G rated tires to replace the factory Westlake that were there. No issues with the Westies, but I've watched Providers take a beating on the flatbeds axles. They seem to work well with abuse.
09-04-2019, 09:16 PM
Provider ST235/85R16. 14 ply rating. Load range "G"
5 star rated on etrailer. Might cost a touch more than goodyears.
I really like them.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
09-15-2019, 03:17 PM
I've been happy with my Sailun tires.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
09-15-2019, 05:18 PM
We're using Westlake 235/85 -16 on a 2019.5 CC 36CK2, probably identical to your 2015 CKTS. 80 PSI would be fine because the CAT scales show we're hauling just under 12K lbs loaded for travel. I run 90 PSI with a TST 507 TPMS and on a 95 degree clear weather days the temp only goes up 10 degrees and psi goes up 15 lbs. Ceramic balancing beads counter-act the TST sensor weight and after 10,000 miles there is absolutely no tread wear.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
10-11-2019, 04:03 PM
I ran Michelin XPS Rib LT235/85 R16 on my Big Country. I was going to swap the wheels and tires with my Silverback I just picked up only to find the Big Country has 8 lugs and the Silvercack 6 lugs. Both are Lippert 6000lb axels...minus one point for the Silverback. I will be putting on the Michelins before too long, don't like the stock tires...I have had good luck with Maxxis too.
10-15-2019, 05:17 PM
I’ve got over 11,000 miles on my 2017 CC 34RL2 on Westlake tires with no sign of were. I don’t know what’s on the market right now but in two years I’ll be looking.
Good luck with your choice
10-17-2019, 09:42 PM
I switched from the G14's to the Sailuns this past spring. Solid tire and no wear so far. Very happy with choice.
2012 40' Silverback
Luke & Carolyn
2012 Cedar Creek Silverback 35QB4
2013 Sierra 3500HD Duramax CC SRW SB 4x4
Andersen Ultimate Aluminum 2 Gooseneck Mount
