Old 05-01-2014, 01:09 PM   #1
Sewhappy's Avatar
Tires
When we picked up our CC36ckts, the tread on the tires looked smooth in some areas. The dealer said this is normal for trailer tires. Is this true? I would think they wouldn't grip the road.
Sewhappy is offline   Reply With Quote
Old 05-01-2014, 01:13 PM   #2
Herk7769's Avatar
A photo would help.
Are the tires ST or LT tires.
ST tires have tread designs to minimize rolling friction (while ensuring tracking with the tow vehicle) and LT tires have aggressive tread designs for traction and grip in all conditions.
File Type: pdf TRAILER LIFE - LT vs ST Magazine Article.pdf (1.91 MB, 134 views)
HAM CALLSIGN - KC3FFW
Old 05-01-2014, 08:27 PM   #3
Sewhappy's Avatar
I don't know about the st or Lt but they are Goodyear. I went on Goodyears website and the tires had the same no tread area so I guess it is the way it is suppose to be.
Old 05-01-2014, 08:31 PM   #4
Plain Old Member
On the CC, it has the Goodyear LT tires. They look WAY different than a regular ST tire. They do tend to look "worn" or not new, but that is what this tire looks like brand new.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-01-2014, 08:46 PM   #5
Hutch333id's Avatar
This is really great info. I thought the outer edges of the Goodyear tires on my new CC looked a little smooth. Now this explains why.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 05-02-2014, 07:15 AM   #6
Sewhappy's Avatar
Glad to see we weren't the only ones who noticed the difference in the tread. When we saw the tire by the door of the camper, we thought, does it come with a bald tire?
Then we noticed all the tires looked like that.
Old 05-02-2014, 09:22 AM   #7
Same here. I thought the GY tires looked like something was not right but after 5000 miles they still look the same.
Sterlingsilver is offline   Reply With Quote
Old 05-02-2014, 09:25 AM   #8
How about a few pictures?
Old 05-02-2014, 10:48 AM   #9
Can do but while you are waiting, check a GY G614 tire at a dealer. The tire has a smooth tread on the 2 outer treads. It makes you think the tire has been run underinflated or out of alignment. Trailer tires are a different breed. I would not use an LT tire on a trailer but some people do. As always, proper inflation, don't overload the vehicle and stay around 65 MPH or less. Have never had a tire problem on a trailer and I've had 5 of them.
Old 05-02-2014, 08:40 PM   #10
Former Full Timer
Duckogram's Avatar
Goodyear G614's are G rated LT tires for the heavier loads of your CC.
The tread pattern is called a highway rib. Goodyear tests them for RV use and publishes proper load and inflation numbers which you can find with a simple search. For your 36CKTS, under normal load you are looking at about 90psi for proper inflation. You will need to weigh your unit to get the exact number. You should not inflate to max pressure (110) for a number of reasons. Here's a link to a nice picture... Goodyear Unisteel G614 RST tires listed by size
BTW, they are rated for 75mph.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
