Old 03-29-2015, 09:40 AM   #11
Jim34RL's Avatar
Originally Posted by ret2006 View Post
The Goodyear G614 tires and 7,000# axles was an option on my CC at a cost of
$2,320.00.
On the 2015 models they are no longer a separate line item. The 16" 8-Lug ST-G-rated tires and the #7,000 LB axles are now part of the Cedar Creek Explore package; which I believe is a mandatory option now. This was listed on the order sheet as a line item when I order my unit in Feb and said see brochure for details.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 03-29-2015, 02:01 PM   #12
My 36CKTS was built the last week of January 2015 and it came with
West Lake tires.
2015 CC 36CKTS
2011 Ford F-250
2003 Harley Ultra Classic
2015 Cedar Creek 36 CKTS
2016 Ford F350 DRW
2016 Harley Davidson Ultra Classic Low
rick03hd is offline   Reply With Quote
Old 04-21-2015, 02:09 PM   #13
So I've got a tire question. I have a 2013 36 CKTS and have the Goodyear tires. The max pressure on the tire reads 110 psi. The sticker on the side of the trailer says 110 psi as well. I was talking to a guy at the campground and he said he always runs his tires at max pressure. So I did that all of last year, never had an issue. So this year I took the trailer to the dealership to have the seals done and they said I should run the tires at 85-90 psi. The thinking was if it's at max pressure, there is no room left for the tires to expand on hot days and long trips.
So my question is, who is correct? What is the correct pressure to run at? I don't have the trailer maxed out weight wise, so I don't think I need to run at 110 psi all the time.
spawnman is offline   Reply With Quote
Old 04-21-2015, 02:14 PM   #14
The tire companies know more about their tires than some RV dealer. The tire companies take into consideration the thermal expansion when they stamp the cold pressure maximums. I would run @ the 110# the tire company states.
Old 04-21-2015, 02:17 PM   #15
Ford Idaho's Avatar
X2
Under inflation is never a good idea.
Old 04-21-2015, 02:28 PM   #16
ok, thank you. I will inflate to 110#
Old 04-21-2015, 03:50 PM   #17
I don't understand Forest River, Heartland Bighorn still comes with Goodyear LT tires and so does Keystone Montana, at Cedar Creek You can't even get the LT as a option now. Berkshire Hathaway must own the tire factory in China
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 04-22-2015, 12:05 PM   #18
I think Old Coot is right. The max pressure stamped on the tire is max COLD inflation pressure. On hot days I have seen pressure go up quite a bit (into the 120s). The TST TPMS will let you watch the tire temp and pressure. As long as you don't have a tire heat up past the limit, you will be OK. Low pressure will cause the tires to run hotter and that could cause a problem.
Skip & Susan Orrell
Hurst, Texas
2013 34 RLSA w/ most of the options
2013 Chevy 3500HD, D/A, DRW, 4X4
WeRCreekers is offline   Reply With Quote
Old 04-22-2015, 12:18 PM   #19
to spawnman, I also have a 36 CKTS w/goodyear tires,thankful for that, myscaled weight is just under 12000# 3000 per tire every thing equal, according to the goodyear load/inflation chart 3042 takes 80# pressure ,I run 90# 3300# to cover any added weight the DW may add, like 200# of dishes she had to have. you can get a chart at www.goodyear.com/rv
Big Bill is offline   Reply With Quote
tire, tires
