10-15-2017, 06:07 AM
#241
Diesels love hard work, but gassers are acceptable too if you have the HP and drive train to manage it. In the end you have to ask yourself, do you really need to spend $6,000 to $9,000 MORE for that noisy diesel?
10-15-2017, 07:24 AM
#242
Well diesels, at least my Ford 2011-2017 are not noisy at all, in fact you can barely hear it running at idle or under power.
The cost, not sure, I think its around $78xx but could be more as I don't pay much attention, I am on my 4th one in my '17 F 350.
Now I have pulled plenty with a gasser under the hood and the difference between plling with gasser and diesel is truly night and day as is the experience, the safety envelope and the reduced stress of driving.
I often pull 12- 14k lbs when fully loaded, in fact I will run heavy in a few hours as we head out on a week plus trip for business. My avg mpg will be about 10.7 - 11.5. I will leave the ranch here in the Tex Hill Country run I 10 to Houston, then up to the Austin area and back home by a week from tomorrow. My trans won't spend its time up/down shifting looking for gears to challenge the Interstate traffic or as I travel the Hill Country which can send a trans into fits with its constant up and down the short hills.
While I typically drive around 65 mph, there are several roads I drive here in Tex with 80 mph speed limits, then I kick it up to 70 mph and if and when I need to pass I have the power to do it even 14k in tow.
Now if your load is just a light 1000 or so lbs the gasser will do fine I use it to pull my small trailers and jet ski which is right at 1000 lbs fully loaded. Gasser, great job, only a minor penalty in mpg, but if you go big the diesel is worth it.
Don
US Army Infantry Retired
Texas Hill Country
Cedar Creek Silverback 29RE
'19 F 350 CC, LB King Ranch Ultimate
10-15-2017, 07:25 AM
#243
I don't know where you get noisy diesel from, my Silverado is pretty quiet. I drove truck to Disney World from NC and back not pulling camper and I got 20.4 miles per gallon running 70mph or better.
10-15-2017, 07:52 AM
#244
Have you listened to any of the newer ones?..................MUCH quieter!
I will admit pulling a ROO you probably don't need one, but my 12,000 5er sails up the Mississippi river bridge behind my Duramax/Allison combo. With my old Ford Gasser, Not so much...........I would be down to 35 MPH with my foot to the floor by the time I got to the top.
The difference is night and day. I will never go back to a gasser for towing!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
10-15-2017, 09:50 AM
#245
If I was pulling 6+ tons I'd have a diesel.
10-15-2017, 10:19 AM
#246
When it comes to choosing gas over diesel for towing, and someone chooses a gas rig, it's usually a financial decision. Then, they try to justify their financial decision by stating gas is comparable.
2017 Rockwood MiniLite 2506S
2022 F250 7.3/4.30
10-15-2017, 10:37 AM
#247
If that were the issue Id buy an older used diesel. In fact, I bought an 08 Chevy 2500 diesel about a year and a half ago with only 35000 miles for less than 1/2 the cost of a new truck.
The decision was a no brainer to me, but I don't ever buy a brand new vehicle. I prefer to let someone else take that huge depreciation hit.
10-15-2017, 11:02 AM
#248
Noisy ? Listen to a gasser screaming to get a trailer up a hill. Todays Diesels are very quiet .
10-15-2017, 11:14 AM
#249
True... but as stated below the resale is very good as well. Think an '08 gasser would bring 1/2 it's cost?
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
10-15-2017, 12:37 PM
#250
I don't think I've ever seen anyone claim they are comparable. But for some of us, you don't need a hammer to swat a fly.
2011 Traverse LT, 3.6L, FWD
10-15-2017, 03:54 PM
#251
❤️6.7 turbo D. ❤️❤️exhaust brake! 11mpg loaded, x country.
2008; 81,000 miles, hug it every morning.....
10-15-2017, 04:52 PM
#252
I haven't been in one newer than 09. [emoji15] it would be great if they were quieter.
A gasser with the right engine and drive train doesn't scream either.
Unless it's a Ram. Can't help you much there. [emoji6]
10-15-2017, 07:32 PM
#253
Pulling 8000 lbs up an 8% grade with my 2500HD gasser with 4.10 gears had to be at redline just to go 45 mph screaming up the hill with trans temps climbing to frightening temps. This was my experience. Now, my Duramax with 3.42 gears pulls the same hill with a new trailer weighing 10000 pounds right at 2500 rpm just as fast as I want to go. There is no comparison between the gas truck vs the diesel pulling real weight. Pulling my 4000 pound boat no benefit to the diesel. Pulling 4 or 5 tons; huge difference.
10-16-2017, 04:53 AM
#254
I agree with you on the hammer vs fly analogy.
I HAVE heard some say (on this very forum) they would NEVER go diesel and they are towing campers as heavy as mine. So on that point I would have to disagree!
10-16-2017, 05:01 AM
#255
[emoji6]
Mine is an 08 LMM Duramax and not loud at all.
gasser doesn't scream.....Basically not true. Most people do not realize that a gasser produces more torque than a diesel. It just does it at the top of its power curve while the diesel gets it near the bottom of its power curve. It doesn't wind up as tight because it does not have to.
So, when a gasser is pulling a heavy load, in TH (as it should always be), and faced with a hill, the gasser downshifts to be able to get the required torque and slowly climbs the hill while the engine is SCREAMING (just as it is designed and programmed to do).
10-16-2017, 06:55 AM
#256
This statement is simply not true. What gas engine out there makes 900+ ft lb's of torque?
10-16-2017, 07:19 AM
#257
Anyone who pays #78K for a pickup truck has TOO Much Money, I paid less than Half of that for my 2015
RAM Diesel Dually New and it is Quiet
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
10-16-2017, 07:27 AM
#258
My 17 F 350 puts down 925 lbs box stock and I get that for about $8k. That is not available at all in a gasser. But if you want serious hp/torque from gasser the tariff will set you back around $20k ++ large for 650/650 hp/torque from the Chev stable.
Don
Texas Hill Country
10-16-2017, 07:30 AM
#259
Saying a gasser doesn't scream is not true. It does not hurt them but pulling a load up a hill with the pedal to the floor in 2nd gear at 35 mph it does scream.
As for a gasser having more torque than a diesel, that is good for a chuckle but drive what you have.
10-16-2017, 08:12 AM
#260
If I can find a 2017 3500 dually LT Silverado at a good price I would trade. I see some LTZ at $67,000.00 and I can't afford that, well I could but I just don't want that much in a truck. I actually paid more than that for DW Mercedes in 13 but I'm not doing that again.
