Old 10-03-2014, 12:34 PM   #21
BandJCarm's Avatar
Oh, I don't doubt it's my fault. But I can't make it make sense TO ME.
I simply figure I now have the truck with enough goose to pull whatever they make, even though I don't want those monster 5er's. Looking at Silverado 29IK, but it's a year away. If my 2500 Diesel won't pull that, I'm gonna......um...........I dunno what I'm gonna do.
BandJCarm is offline   Reply With Quote
Old 10-03-2014, 01:03 PM   #22
camper1999's Avatar
Your 2500 diesel will more then pull that. I have the 29re and a 2500 diesel. I don't even know that trailer is back there.
2011 GMC 2500HD Diesel
Old 10-03-2014, 05:34 PM   #23
wbdavey's Avatar
Originally Posted by GOTTOYS View Post
The trailer brakes stop the trailer, the truck brakes stop the truck. Just like with any truck/5th wheel combination. The f250 and the f350 have the exact same size brakes in the single rear wheel configuration. Nothing I would worry about. Maybe you haven't noticed how many single rear wheel trucks are towing trailers recently?
I respectfully disagree. My 05 F350 SRW was the highest GVW available without DRW. The local brake shop replaced the rear rotors and had F250 rotors in stock. The 250 rotors and the lighter GVW F350 SRW's would not fit. They finally tried DRW rotors (bigger) to get the correct replacements.
So it is incorrect to assume that all 250's and 350's have the same suspension and brakes.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 10-03-2014, 07:34 PM   #24
MagnoliaTom's Avatar
I asked a similar question. Do what you feel is the right answer for YOU. I will be towing a big fifth wheel with my 3/4 ton Powerstroke diesel. If after towing it and circumstances change my opinion, then I'll decide on a new TV. IMO though, I think your 6.7PSD can do the job
2014 Freedom Express 320BHDS Liberty Edition 50th Anniversary
2005 F250 Lariat SuperCrew 6.0 PS Diesel
2004 Excursion Limited 4x4 6.0 PS Diesel
2000 Excursion Limited 7.3 PS Diesel Sold:crying
MagnoliaTom is offline   Reply With Quote
Old 10-03-2014, 07:35 PM   #25
Always Learning
Originally Posted by Borrell View Post
I know this has been discussed but my head is spinning. We are moving up to our first 5th wheel from our 1st TT. I'm a physician with OCD tendencies like everyone else but this makes no sense and I can't seem to find a consensus. ... That leaves 2500 for the pin weight which is a 12,500 loaded trailer. I think this is the route I'm going. I know most people probably go by the GCWR and max trailer weight. Safer ones may use the axle method. The GVWR seems completely useless. These people must stay in hotels. Comments?
You have a perfect grasp on this:
1) The GVWR is defined by the truck manufacturer.
2) The GVWR - actual weight of the truck = actual usable payload
3) Many times trucks are overloaded on GVWR. When this is the case, a lot of people use different formulas, feelings, and personal choices as to why this is acceptable to them.
4) There is nothing documented by the truck manufacturers for how GVWR is calculated. There is a lot of conjecture about what is different between a 3/4-ton and 1-ton trucks. Additionally, I laugh when you read one person say "oh, I tow whatever I want with this truck" and another posts "oh truck makers way over exaggerate their abilities".
5) Lots of liability concerns are raised by one side and summarily dismissed by the other.
You have to choose what is acceptable to you and make an educated choice as to what works best for you. You'll always find someone that agrees and someone that disagrees- it doesn't make it right or wrong.
out there.
Old 10-08-2014, 08:53 PM   #26
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Traded last week for GMC 2500HD, SLT, Crew Cab, 4WD, 6.5 ft bed, Duramax/Allison....manual shows 15800 max fifth wheel trailer weight....traded Monday for a 2014 Silverback 33RL with dry weight of 10800 with delivery for next Monday, Oct 13....ready to put it on the road....it better work....first time out of the gate with a fifth wheel....been towing a 8000 lb bumper pull.....my heads spinning from reading this thread....lol.
Lloyd & Kathy Martin
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014-38nights/3500 mi; 2015-66nights/6260 mi;2016-44 nights/6106 mi;2017-65nights/6992 mi;2018-47nights/7376mi;2019-65nights/7825 mi;2020-59nights/4142mi;2021-39nights/3072 mi;2022-59-nights/6149 mi;2023-36nights/3001miles.
jtownstumpjumper is offline   Reply With Quote
Old 10-08-2014, 09:27 PM   #27
jtstromsburg's Avatar
You'll love it!! I found our Fifth wheel tows much nicer and no sway, ever. I went from a little 30' TT weighing 7k lbs to a 40'long, 13'-6" fiver weighing over 13K lbs and love it! I get about the same milage, but much less stress. Happy Campin!!
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 10-08-2014, 10:29 PM   #28
Chuckinca's Avatar
According to the Mfgr numbers, my Ram 3500 6.7L Diesel has a GCWR of 21,000 #.
TV Curb Wt of 7,400#
Which leaves 13,600# for everything else.
No way I can legally tow a 13,000# whatever.
How do you do it with a 3/4 ton?
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
Chuckinca is offline   Reply With Quote
Old 10-08-2014, 10:37 PM   #29
Guess I'm just that good.... I know I'm over a bit on gcwr, but under rear axle and tire ratings. Gasser too! Pulls great, I can stay above 60 up hills and never go much above 4K rpm. The other big plus is all the nice people I meet at every gas station I stop at, which is most everyone I see.
Joel and Teresa
2016 Sabre 34TBOK
Old 10-08-2014, 11:22 PM   #30
Truck is big enough
No math hoops to jump through for me. Tractor pulls our 5er, 16k and could pull another 16k without much stress. 1400 RPM, 63 MPH, 12th gear. People have said "ya got a big enough truck there"? "Yes I do, do you"? Point is I've seen plenty of folks that don't have enough power in their TV, whether it be bumper pull or fifth wheel, and many do not have the correct suspension which IMO is just as bad as not enough power.
Dave
2014 Sandpiper 35ROK
2004 Volvo VNL64T 630 left tandem
D-12 435 HP 740 CU
Western Golf and Country Cart (custom body, EZ-GO frame)
Arguing with some people is like trying to smell the color 9
Volvodriver is offline   Reply With Quote
Old 10-08-2014, 11:45 PM   #31
Well, my educated guess from maintaining dozens of theses is that they had the rotors for a 99-2004 SRW in stock which are smaller than the 2005-12 SRW rotors by about 7/16 dia. The DRW rotors 99-04 were same dia as SRW 99-04, The "BIGGER" DRW rotors for the 05-12 are a mere .33in dia bigger than the SRW and only used on duallys since it was a completely different axle, Manufacturer, size and track. Ford 10.5 SRW vs Dana 80 DRW
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
Bunkfamily is offline   Reply With Quote
Old 10-09-2014, 11:33 AM   #32
This is from Fords fleet site for towing and weight/dimensions.
(4) Gross Axle Weight Rating is determined by the rated capacity of the minimum component of the axle system (axle, computer-selected springs,
wheels, tires) of a specific vehicle. Front and rear GAWRs will, in all cases, sum to a number equal to or greater than the GVWR for the particular
vehicle. Maximum loaded vehicle (including passengers, equipment and payload) cannot exceed the GVW rating or GAWR (front or rear).
How does one decipher the last sentence? Does it mean you can exceed the GVW if you don't exceed the FAWR or RAWR but not both at the same time. Since The GAWR is always higher than the GVW on HD trucks it seems that Ford is giving you the option of which to stay under. What's the point of Ford, GM or Ram listing the RAWR,FAWR if they never intended owners to not exceed it. Why not just list the GVW and be done with it? The only thing the GVW does is determine the payload rating from an empty truck. The RAWR/FAWR does nothing to determine the GVW.
goduc is offline   Reply With Quote
Old 10-09-2014, 07:08 PM   #33
According to the tow info for my exact truck, it says 15,800 5er towing. I Keep it simple. My door tag says 2546 lbs total cargo. Pin is 1750. Leaves me about 800lbs for family ect. I put the luggage in the trailer and try to keep just the bare essentials in the truck for more room. Family weighs in at 435 so I can throw in 365 lbs more bs.
My 5er loaded total weighs 12k and my truck pulls and stops with zero issue and once in the highway you can't tell it's back there unless we hit some big bumps.
Keep it simple and safe and go have fun. I would put in some air bags with on board air for your Ford but otherwise truck on.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 10-09-2014, 07:11 PM   #34
You are correct.
The Ford F-250/350 do have minor changes unlike Chevy and possible Dodge. I know with the new Chevys, the only difference between the 2500 and 3500 is the rear spring pack. All other is the same.
Doc
towing
