Old 10-17-2016, 12:04 PM   #21
Left Coast
Only if you can hold your breath!
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
Old 10-17-2016, 12:19 PM   #22
My tire gauge says 120 lbs
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 10-17-2016, 07:55 PM   #23
Yes go by the arrow. Our 36ckts takes 100 psi to get it on the point of the arrow.
Steve & Jean
Furbaby - T.J.
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
Stevemc is offline   Reply With Quote
Old 10-19-2016, 10:08 AM   #24
Does adding a TrailAir pin box change the height of your camper?
Old 10-19-2016, 10:11 AM   #25
Left Coast
I asked that also, and never got a response...needed a measurement from bed to pin plate with plate level
Old 10-19-2016, 11:31 AM   #26
I called the factory and they said it might change the height three or four inches. I'll have to hook up camper and check the height on the road. I wonder what would happen you let the air out of the bladder, at least temporarily
Old 10-19-2016, 11:47 AM   #27
W5CI's Avatar
I run around 40 lbs of air in my TrailAir, 60 lbs is way to much. it is solid with 60lbs
2004 Cedar Creek 30RLBS RV FlexArmor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42 Garmin 760RV
Firestone Air Bags/Air Lift Wireless One Controller
40 Gal TransferFlow fuel tank
Amateur Radio W5CI AR-0043-29
2016 Days Camping 50
W5CI is offline   Reply With Quote
Old 10-19-2016, 12:01 PM   #28
W5CI's Avatar
The TrailAir is adjustable like any other pin box.
Old 10-19-2016, 12:08 PM   #29
Would pin weight affect the air in bladder? When do you air up the bladder, when hooked up or not hooked up
Old 10-19-2016, 12:22 PM   #30
Jim34RL's Avatar
Yes , also air temperature plus elevation will also affect the amount of air required to level the shock cover. I always fill the air bladder when I hook up and on level surface. I do not check the air pressure at all, I rely on the line that the arrows point too. When the shock cover is even with this line, then I stop putting air in the bladder. I carry a portable air tank that I use to inflate the air bladder. I fill this from my compressor as needed. I have even let air out depending on elevation, I check the air bladder daily if we are hooked up and towing when we start out first thing in the morning.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, 100K+miles
