Old 12-16-2014, 06:26 PM   #1
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Trailair Air Pressure?
New to fifth wheels and new to Trailair....Only have pulled our 2014 Silverback 33 RL one time and that was around Nov 1.......Noticed this week the airbag is flat.....how long can one expect the airbag to maintain it's pressure or is this something that one has to constantly be airing up?
Lloyd & Kathy Martin
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi...
2017-65 nights/6992 mi.; 2018-47 nights/7376 mi; 2019-56 nights/6987 miles; 7 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 12-16-2014, 07:10 PM   #2
It should hold for several months. Air it up,take a spray bottle with soapy water in it and start searching for the leak
donniedu is offline   Reply With Quote
Old 12-16-2014, 07:35 PM   #3
SilverbackMel's Avatar
I have the identical rv and pin box. You HAVE AN ISSUE, leak😒. Picked up my 2015 last April and it has traveled several trips, been in warm climates and stored in freezing weather. Picked it up today, pulled it 62 miles and it looks as fresh as a pretty girl at a prom 😁. Never put an ounce of air in it yet. And NO, ain't flat or soft!!
SilverbackMel is offline   Reply With Quote
Old 12-16-2014, 08:21 PM   #4
I have the same trailair on my Cedar Creek and the most time I get before it goes soft is 1 month. The trailair was checked by the dealer twice and no leaks were found, I add air before each trip which is no big deal but it would be nice if it stayed inflated longer.
Pitcrew18 is offline   Reply With Quote
Old 12-16-2014, 08:26 PM   #5
We have to top ours off each trip (usually about a month between trips so far)... 2-5 lbs of air so not too much.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 12-16-2014, 10:10 PM   #6
I usually check mine each time I get ready to pull, and it normally requires a little air if it's been more than a week since I last pulled it. I keep a 12 volt compressor in the basement and it only takes a few seconds to get it back where it should be.
Carroll & Betty Davis
2013 Cedar Creek 34RLSA
2011 Ford F250 Superduty Powerstroke
cbari is offline   Reply With Quote
Old 12-16-2014, 11:28 PM   #7
Thanks to all who've added comments.
Old 12-17-2014, 11:57 AM   #8
Mddle of the Rd Extremist
MeepMeep's Avatar
We have the TrailAir setup on our CC 38FL as well. I check it every time we hook up, but I haven't had to put any air in it for over a year....
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 12-17-2014, 12:15 PM   #9
CCRVOC
Ramblin Recks's Avatar
I check mine before every trip, and it has always needed a little air added.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 1000w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 12-17-2014, 12:53 PM   #10
Mine loses air but it doesn't go flat. I put 80 psi in it and the fiver sits where it should according to the arrows.
Pipeman is offline   Reply With Quote
Old 12-17-2014, 01:04 PM   #11
2015 Silverback/2014 F250
I just purchased a 2015 CC silverback 331k and it doesn't have a air on box. I was wandering if it helps and how much it will cost, also is this something I can add?
chisumbella is offline   Reply With Quote
Old 12-17-2014, 01:16 PM   #12
Have a look here; Air Rideā„¢ Pin Box
I traded my pullrite super glide for the one I have, plus installation. Smoother ride. You can look in your rear view mirror and watch it work.
Old 12-17-2014, 03:05 PM   #13
KennyGolub's Avatar
On the 5er I just got rid of, I would check it once every month or so and at the begining of the season.
If I wanted to check it after the trailer was on, I would fill it to where the arrows pointed. Usually around 80lbs.
KennyGolub is offline   Reply With Quote
Old 12-18-2014, 12:57 PM   #14
I got my TrailAire Tri-Glide installed last summer at the big FROG rally. Several of us Creekers got a VERY good deal from Lippert on the pin boxes. I has a stock pin box on it before this. I might have been imagining it, but I could tell the difference almost immediately. And on those bad interstates with the concrete sections where we used to get that "buckin' bronco" sensation (chucking?), the difference in the ride is amazing. We will still get a little bouncing if we hit a VERY bad section, but it dampens out quite fast. But I'm convinced it is the best money I've spent since I bought the Creek!
I started out carrying about 90 psi in the bag, but deflated it to about 80 and that's where I seem to like it. Bag seems to be holding pressure well, although I haven't been out in the camper for a few months. We'll know more this summer when we get rolling again. I too carry a 12V compressor and sometimes a 150 psi pancake compressor with me. The pancake requires 110V, of course. But for the air bag the little 12V works very well. (Not so much for my 110 psi tires though ).
Skip & Susan Orrell
Hurst, Texas
2013 34 RLSA w/ most of the options
2013 Chevy 3500HD, D/A, DRW, 4X4
WeRCreekers is offline   Reply With Quote
Old 12-26-2014, 11:05 PM   #15
I have never looked at what pressure I have. I set mine about 1/4 inch down from the top of the arrow on the front of it. My pressure will vary according to how much of a load I have in the trailer. I use a 12 volt compressor to adjust it.
GOTTOYS is offline   Reply With Quote
Old 01-20-2015, 07:58 AM   #16
Kampnnit's Avatar
Not long after I purchased my 33RL I installed a Trailair TriGlide. What a difference! To make getting the correct amount of air in the air bag, I installed a gauge. After I installed it, I hooked up the truck and adjusted the pressure to get the correct ride height. Once I got the height correct, I unhooked the truck and noted the pressure. Now I can add air to the air bag without need to hook up the truck. For my camper all I need is about 50 PSI.
Kampnnit is offline   Reply With Quote
Old 01-20-2015, 09:01 AM   #17
Enjoy the ride!! TrailAir is simply GREAT! 😃
pressure
