Old 05-22-2015, 09:17 AM   #11
mcnabbwr's Avatar
Originally Posted by donniedu View Post
Forget those junk 12V compressors. They can take for ever to raise the trailer, if ever. Instead, go shopping and buy yourself a 150PSI pancake compressor. Bought one on sale at Lowes last year. Was so happy with it, I gave away my big compressor. Easy to carry and store, and as a bonus when fully pressurized will hold the pressure for a week or more.
Not all are junk, however with your compressor if you need it along side the road you will need a inverter or generator.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is online now   Reply With Quote
Old 05-22-2015, 09:31 AM   #12
I just use a cheap one. It works fine and I can adjust my air pressure in a few seconds. However, I do carry a spare just in case. I've never used it for my tires as I also carry a small 110 volt compressor that I can use when I'm parked somewhere. If you shop around you can find a adapter that will allow you to use the cigarette lighter type plug on the compressor and plug it into the 7 pin plug on the rear of the truck...Works very well for me. You could also use just a hand tire pump. The airbag on the hitch doesn't take much air.
GOTTOYS is offline   Reply With Quote
Old 05-22-2015, 09:56 AM   #13
Campingnut's Avatar
Originally Posted by mcnabbwr View Post
There are a lot of different compressors on the market, just be sure it will handle your tires. This is what I have. It is a great unit but is a little pricey.
VIAIR Corporation - 400P-RV Automatic Portable Compressor (P/N 40047)
I was to cheap to buy the 400P. I have the 300p and it works just fine for everything
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 05-23-2015, 12:15 AM   #14
wanderer69's Avatar
If you are also going to be using it for tires also, you may want to consider one of the 110 volt 125 or 150 PSI tank type. The tire pressure on your new 36ckts is 110 PSI.
Tom
2015 Chevrolet Silverado LTZ 3500 CC DRW Diesel
2014 Cedar Creek 36CKTS
wanderer69 is offline   Reply With Quote
Old 05-23-2015, 10:14 AM   #15
B and B's Avatar
I have a Coleman compressor from 1972. It works just fine on 12 and will pump up to 100 psi if needed. Some just work forever,
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 05-24-2015, 12:00 PM   #16
Fulltime family RVer
For the pin box, I find it is easiest to use a good quality bike pump.
For tires, I use a 3 gallon Porter Cable(?) pancake compressor - $100 from Home Depot.
Old 05-24-2015, 01:29 PM   #17
Does anyone topoff their Trail-Air before connecting to the truck? The correct amount of air for mine is 94#.
I'm aware what the Trail-Air manual says about it.
2015 38CK
2005 F350 Diesel Dually
2009 Honda GL1800 Goldwing
Gordog is offline   Reply With Quote
Old 05-24-2015, 08:44 PM   #18
Top it off till the arrows line up.
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 05-29-2015, 08:09 PM   #19
Kampnnit's Avatar
I service mine to 40 lbs before hooking it up. I added the gauge so I can easily air it unhookedClick image for larger version
Name:	ImageUploadedByForest River Forums1432948140.061508.jpg
Kampnnit is offline   Reply With Quote
Old 06-01-2015, 08:32 PM   #20
85 psi before I hook up
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
pressure
