Old 06-19-2013, 12:33 PM   #1
Trailer Wide Open Around Landing Gear Strut
I was out doing some stuff on the camper the other day and noticed something that has me concerned. I had the door to the Level-up System open and noticed that there is an opening around the front left strut that comes into the front storage compartment. Now it has probably been that way from the start and this is the first time I noticed it and became concerned. It's obvious that critters could get into the front storage area. I'm thinking mice, squirrel-sized critters, or maybe snakes. Could they then get into the camper? I looked around in the compartment and didn't notice any openings but now I'm wondering. Is this opening around the strut common? Anyone ever have any critter problems caused by this?
Skip & Susan Orrell
Hurst, Texas
2013 34 RLSA w/ most of the options
2013 Chevy 3500HD, D/A, DRW, 4X4
WeRCreekers is offline   Reply With Quote
Old 06-19-2013, 01:01 PM   #2
ret2006's Avatar
Had our 34 RLSA a little less than a month and noticed the same thing. In previous 5th., wheels under the propane tanks which has to have ventilation, there was a opening. I always put a open container of moth balls there to keep the wasp out but the large opening you are talking about could allow a a large animal in. Interested to see what others are doing with this space.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 06-19-2013, 01:51 PM   #3
On our 38FL there is metal all the way around the cylinder - there is probably only 1/4" or so space around that you can "see" into the storage compartment.
Still probably enough room for a bee, but because of the angles and such, not likely a small animal could get in to the area where the small space is there.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 06-19-2013, 03:55 PM   #4
Former Full Timer
Duckogram's Avatar
1/4" gaps on both sides. Used foam backer rod and silicone adhesive over the top to seal it tight. A friend of mine said that if boats were made like trailers, they would all sink.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 06-20-2013, 12:36 AM   #5
Exclamation Sheet Metal
We had a mouse come up that same landing gear strut in our Silverback 35QB4, get into the garage and chew through our BARBQ bag! Had never had a rodent issue in four years at the exact same location with our previous trailers. This was one week after we brought the new fifth wheel to the location!
Immediately took it to our local dealer, they installed a piece of sheet metal by riveting it in place and then used spray foam, then a coating of rubber spray over that. It is bomb (and rodent) proof now, and have never had a rodent issue again.
If you are handy with the tools, you could do it yourself in a couple of hours max. We had the dealer do it and it cost us a couple hundred bucks, but we have peace of mind that rodents are kept out by the fix.
I highly recommend that you do the same...that strut is a rodent highway, and it is only a matter of time!
tyee43
2012 Cedar Creek Silverback 35QB4 "Silver Edition"
2011 Chev Silverado 3500HD Dually Duramax Turbo Diesel - Allison Trans / PullRite 20.5K Super 5th Wheel Hitch & SuperRails / Trailair Tri-Glide Air Ride Pin Box #21,000 / Honda 3000i Handi
mdamm is offline   Reply With Quote
Old 06-22-2013, 08:57 AM   #6
ret2006's Avatar
Picture of the landing gear opening!
Here are a couple of pictures of the opening around the drivers side landing gear. The opening is actually larger than I first thought. Certainly an animal the size of a cat, opossum, raccoon, or birds, could easily make a home in the front of our Cedar Creek basement. Any suggestions on what others are doing about this would be appreciated.
Old 06-22-2013, 09:03 AM   #7
Yuck - outside of ours is the same. Inside is not.
ID:	33781   Click image for larger version
Walter & Donna
Old 06-22-2013, 09:38 AM   #8
ret2006's Avatar
I really don't know what they (Cedar Creek) was thinking when they designed this. I think we have all dealt with bird nest in the pin box but this is bad. Leaving it up the the purchaser of a new unit to deal with sealing up openings like this??????
Old 06-22-2013, 09:58 AM   #9
Silverback 29re
I posted on this very subject last year on 11-21-2012, I guess it is a problem with more units than the silverback?? I don't think Forest River is to concerned with this problem as I spoke (phone) with an engineer at the factory about this issue last year. I happen to know a person ( Oakman) who is going to Goshen in August and will be bringing this issue up with Forest River, I guess we will all see what forest river intends to do about it??
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 06-22-2013, 10:53 AM   #10
Campfire Master
I would try some spray foam. Kinda lay some tape over the area, the coat the other side with foam. Once the foam hardens up there will be no need for the tape. Great Stuff has a foam designed for pest blocking. Great Stuff
John
AVid is offline   Reply With Quote
