Old 07-25-2014, 04:50 PM   #1
Trojan vs US battery?
Interested in feed back on which brand might be better than the other?
Thanks!
LJ
Truck 2013 GMC 3500 SLT HD Dully ,Ext.Cab,air bags.
Camper's:John,Angie,Coco & Norris
RV: 2011 Cedar Creek 34RLSA
Past RV's: Misc.tents,V.W.Campers('65,'69) 2012 Arctic Fox 25S.
[B]Camping Day's: Never Enough
Little John is offline   Reply With Quote
Old 07-26-2014, 08:02 AM   #2
Campingnut's Avatar
I have had very good luck with US batteries. I can not compare the 2 as I have never had a Trojan.
Tim and Bev
2013 Cedar Creek 34RLSA gone trying to find my way back, Magnum 2800w inverter, 560w of solar.
2020 F-350
Campingnut is offline   Reply With Quote
Old 07-26-2014, 08:38 AM   #3
Unfortunately there is no real definitive place to get emperical data on deep cycle batteries .In general though, the heavier the battery within your group, the more likely the battery will perform. It's even difficult to determine performance between users, because of the different battery loads placed on each battery (i.e. boondocking vs. Jellystone Pk)
I suggest you read up on deep cycle batteries, as there is excellent advice on how they function and proper maintenance.
Old 07-27-2014, 02:25 PM   #4
racer4's Avatar
I replaced my Trojan T-105 batteries after eleven years with new Trojans. They still worked fine, but I was going on a long, expensive trip and didn't want to push my luck with eleven year old batteries.
I have never used US batteries.
I use a four stage Progressive Dynamics converter to keep them properly charged.
Chris and Pat
2023 Ram 3500 Cummins Aisin Dually, Auto Flex Air Ride Rear Suspension, B&W RVK3600 hitch
2022 Grand Design Reflection 303RLS
2024 Winnebago Minnie 2327TB B&W Continuum Hitch
racer4 is offline   Reply With Quote
Old 07-27-2014, 02:44 PM   #5
Witch Doctor's Avatar
You will not beat a Trojan battery, the difference is the cost, IMO they are the best on the market. But very expensive. It up to you but like I said they are the best that I have found. It is also depends on what kinda of camping you do. Boondocking nothing better, CG any true deep cycle would do. Or even interstate duel will work well for many years.
Coachmen M/H
Concord
2018 / 300 DSC
Old 07-27-2014, 08:46 PM   #6
camaraderie's Avatar
You should read Trojan's response to USB's claims.
http://www.trojanbattery.com/pdf/The...%20Battery.pdf
Based on this and Trojan's long history of quality and customer satisfaction...I'd give the edge to Trojan. Probably hard to go wrong with either brand though! I like the EastPenn/Deka's myself in a 12V for value/performance. Marine Master batteries that have DC in the model # are their true deep cycle models...Avoid those with DP (dual purpose) in the model number.
camaraderie is offline   Reply With Quote
Old 07-27-2014, 09:20 PM   #7
Incheon, S. Korea
BigBaron's Avatar
Ouch. USB batteries seem a little snake oilish...
Anyone use them?
Me, Julie, Lil' Barry, Faith, and OSD Fang
2012 Coachmen Clipper 126 - Don't even have a TV anymore.
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 07-27-2014, 09:49 PM   #8
textman's Avatar
I installed 4 US batteries and a single point watering system. They are performing great and keeps our residential fridge cold while traveling. Most batteries will perform well if you maintain them properly.
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded
Loving Life
textman is offline   Reply With Quote
Old 07-27-2014, 10:03 PM   #9
Bingo!
BTW...what watering system are you using and are you happy with it or does it have some downside?
Old 07-27-2014, 10:15 PM   #10
textman's Avatar
Originally Posted by camaraderie View Post
Bingo!
Pro-Fill system. Works great, just place the hose in a gallon of distilled water and pump until bulb is hard.
Loving Life
Old 07-27-2014, 10:48 PM   #11
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
John, try Canadian Energy (formerly Battery Direct) Canadian Energy | Renewable Energy Suppliers & Battery Suppliers in Calgary or in Medicine Hat when you're in the area, Shayne upgraded the battery bank in our trailer and installed a Xantrex SW 3012 for us.
John
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 07-27-2014, 10:51 PM   #12
Thanks...will put it on the shopping list for my new baby!
________
Cam
2015 Georgetown 280DS
battery
