Old 11-01-2014, 07:06 PM   #11
mycedarcreek's Avatar
That's right it's a load boss and no I do not have any other tire on my rig and yes I did have pressure monitoring valve stems
mycedarcreek is offline   Reply With Quote
Old 11-01-2014, 07:07 PM   #12
And you can try to prevent tires from blowing but by monitoring the tire pressure weather and it gets hot or it's a low does help but when it's time for tired of blowing its not going to tell me that on the pressure monitor I got my money's worth out of those tires I've had him for 7 years had shown hardly any sign of wear and tear and I didn't know it's about time to change them out I have a tough time replacing tires that don't look worn
Old 11-01-2014, 07:10 PM   #13
Originally Posted by youroo View Post
The tire in your Pic.is a (LOAD Boss). ST do you have other tires on your unit? Youroo!!
[QUOTE=mycedarcreek;729559]And you can try to prevent tires from blowing but by monitoring the tire pressure weather and it gets hot or it's a low does help but when it's time for tired to blow its not going to tell me that on the pressure monitor I got my money's worth out of those tires I've had him for 7 years had shown hardly any sign of wear and tear and I did know it's about time to change them out I have a tough time replacing tires that don't look worn. My fault for not reacting sooner.
Old 11-01-2014, 07:14 PM   #14
I bought the pressure monitoring system at Camping World it was on sale for $269 and I have all my tires monitor 4 on the trailer and 2 the truck all to the rear
Old 11-01-2014, 08:02 PM   #15
Tire and RV damage
My tires were 2 years old, properly inflated and checked daily. No signs of wear or alignment issues. Separated and blew quickly. This was prior to tire pressure monitors purchase. Steel belts acted like a whip and bent slide frame and ripped out underbelly coroplast and more. And yes, an alarm would have gone off and perhaps if I noticed and stopped quickly it would possibly saved my wallet some pain. Each case is different. If I can travel at 62mph and not feel a thing, imagine possible accident if other tire blew and control was lost?! Not good!
My Michelin truck tires looked brand new. Replaced all at 45,000 miles because they were 6 years old. 5 years would be max on RV tires for me. This is an industry wide weakness. My unit is a 2015 and will see new tires in 2017 or sooner. As we say in motorcycling, the only thing that separates your butt from the road is your rubber! Nothing makes a day worse than lying in the street!
TPMS may not cure all, but it may save you from an accident!
Be safe out there.
SilverbackMel is offline   Reply With Quote
travel
