Old 08-30-2014, 03:36 PM   #1
BoatDude's Avatar
TV = 2014 Ford f350 dually
My new F350 dually lariat is driving me crazy. The darn center cap on the rear aluminum wheel keeps falling off...twice now. At over 164 bucks at dealer to replace, I guess I have to leave them ugly axle covers show on my new 70k truck...yuck. I can't believe they use those cheesy little spring clips to hold on a big chrome center cap. They don't even have a spring clip for each lug nut. I'm fuming over this. Anyone else dealing with this crazy issue? Looking for a good replacement?
2013 36 CKTS
2014 Ford F350 CC/DRW/PSD/Lariat/
Factory Installed Reese Custom 25K/
ReTrax Pro Cover
BoatDude is offline   Reply With Quote
Old 08-30-2014, 11:25 PM   #2
Plain Old Member
Hadn't had that luck with ours. Last 2 F-350's had the caps, first one had steel wheels and simulators. I suppose I've gotten lucky. I would actually rather have steel wheels and simulators on mine, but it came with the aluminums. I prefer the steels as you can put any wheel in any location. Not so on the aluminums at all, unless you remove tires.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 08-31-2014, 07:00 AM   #3
I had a 2011 dually and now have a 2015 dually and have never had a cover come off.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 08-31-2014, 07:41 AM   #4
They fall off at work due to too much heat we have found out. Do you have a break problem or parking brake sticking creating heat
clutchd is offline   Reply With Quote
Old 08-31-2014, 09:05 AM   #5
BoatDude's Avatar
Wish it had the steel rims also. I have 6k on it and the passenger side rear has never fell off. The left side is the culprit. No heating issues I know of. I drove 3k miles on the original and no problems...so I baffled on this. The only thing I know is to replace the short lug nuts with longer ones an try another another expensive center caps. At least it can move a little before falling off. The only other option is to replace the wheel with custom wheels. I wish they made more after market option for this style of rim.
2013 36 CKTS
ReTrax Pro Cover
2014, f350
