Old 09-04-2013, 10:40 AM   #11
Thanks for all the help; but, no cigar!
Hi everyone,
Being new to the Forum, I wasn't sure if anyone was listening; however, I sincerely appreciate all the replies.
Our Cottage is equipped with a crank up Winegard bat wing antenna. The TV is a Jensen, but, it's not the motorized mount. I can't find any information in the owner's manuals supplied with the RV that show how the TV is mounted. I'm waiting for the dealer to find out either from his techs or FR how to get the TV off the mount and see what's behind it.
I've had a TV camera behind the TV set and don't see a wall plate. It appears that the coax just comes out of a hole in the wall. There's a second F-connector outlet plate in the bedroom, but, no amplifier control there.
On the outside of the RV, there are two F-connectors for "cable" and "satellite". The two connectors in the bedroom are labeled "TV antenna" and "satellite dish hook up". My cable signal from the outside comes out of the "TV antenna" port in the bedroom.
I've spoken with several folks at the dealership and several other FR owners who state the antenna amplifier control is located behind the "main" TV; but, until I get the TV off its mount (without damaging something), I won't know if this is the case.
If I ever get the answer, I'll give a full report here.
Thanks again to everyone ...
Frank
KR1ZAN is offline   Reply With Quote
Old 09-04-2013, 11:11 AM   #12
Former Full Timer
Duckogram's Avatar
Frank,
All of the Jensen wall mounts are lift off. It does require a little encouragement to get the TV past the detent...
Ducky
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 09-04-2013, 12:02 PM   #13
I don't agree that the booster control has to be where the main TV is. It could be in the bedroom. Could you please take a picture of that two-outlet plate in the bedroom and post it for us here?
Old 09-05-2013, 10:13 AM   #14
Bedroom TV Plate Photo
Howdy,
I'm sure you're looking for a small button on the plate, but, it's just a dual female F connector plate. I removed the plate and saw only two mating wires inside the wall. No amplifier. No splitter. Photo of plate attached (I think).
My dealer is sending a service tech out Saturday (9/7) to look at several issues and, hopefully, the antenna amp will be one of those. The dealer has a call and email into FR, but, the call load is so great that we're told to expect 48 to 72 hours for any kind of response -- which may be an idea of how long it will take to provide any kind of solutions.
Frank
Old 09-05-2013, 10:19 AM   #15
I guess I used the wrong button to add a photo, so I'm attaching a jpeg file.
Frank
Howdy,
Frank
Old 09-06-2013, 11:24 AM   #16
For the actual answer I would call CC..
However thinking out loud - this is a Park Model - might it be possible they hardwired the antenna to be on all the time???
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 09-06-2013, 01:33 PM   #17
The problem with that theory is that it leaves no way to switch between the "Park Cable" input and the OTA antenna.
Old 09-10-2013, 11:44 AM   #18
Here's the answer!
A technician from our dealer came out Saturday. He was strong enough to lift the Living Room TV off the mount -- snug fit. Behind the TV, approximately centered in the cabinet opening, was the 120V outlet, TV cable/amplifier switch and Auxiliary interface for Satellite. The Tech didn't bug this out, but, I will in the future, to determine if Aux is the coax line to the bedroom.
I'm including the photo of the plates in a photo below. Also, the Tech adjusted the mounting bracket to allow the top of the TV to be relatively easily tilted forward, so that one can get up on a small folding ladder and reach behind to toggle the TV Amplifier Switch.
Somewhere in the future I plan to determine exactly which amplifier plate this is and look into remoting the power switch. It's ridiculous to have the TV plate mounted where it is.
Thanks to all of you who contributed ideas and suggestions.
Frank
Old 09-10-2013, 12:26 PM   #19
Wow! That's close to the most ridiculous thing I've ever seen! Not only do you need to get to that switch, but you have to connect your Sat receiver to those jacks as well. What were they thinking.
You won't be able to just remote the switch as you said. You need to move both of those plates to a place where you can reach them. If you have a place/cabinet where you would install a Sat receiver, I would suggest just remounting them in there (keeping in mind that your TV still has to connect to it as well). Do you have room on the wall where the TV mounts that is not behind the TV?
