Old 12-04-2015, 04:34 PM   #11
steelpony5555's Avatar
Yes it is porcelain and is a swirl flush....I did see the plunger when I took the pedal off...have to check the back side when I get home...had a heck of a time getting the pedal back on...guess that's why it has a stamp on it Do Not Remove....but you have a heck of a time reading it if you're a big guy trying to get wedged in between the toilet and shower....probably gonna be more of a good time to try and see what's in back to get to the valve lol lol.....It has stopped leaking for now but I don't trust it.....Thanks
From Central Texas
2014 Cedar Creek Silverback 29IK
2010 Dodge Laramie 3500 Dually
My Steelpony....2007 HD Ultra Classic...done up in a memorial to the 343 firefighters who died 9/11
Never Ever Forget....yes I was a Volunteer FF for 20 years........
steelpony5555 is offline   Reply With Quote
Old 12-04-2015, 09:02 PM   #12
VinceU's Avatar
Originally Posted by bubbles View Post
No cable on a 310 toilet just a valve controlled by the eccentric pedal shaft pushing on the valve shutoff plunger. And as you say 4 screws and the vacuum breaker hose & main water connection and it's a done deal.
Not sure of mfg. or model. Cable or cam, valve is $25 or so.
Old 12-04-2015, 09:50 PM   #13
Well it appears the valve is held in by clips...is there an easy way to get it out without breaking something.... I know it probably will just pop out but before I go messing around and break something I figured I would ask....
Old 12-05-2015, 06:49 AM   #14
bubbles's Avatar
If you have a 310 (of which were not 100% sure of) here is the parts breakdown. Install is with new part. The valve is also available on ebay/amazon etc. Yes clips but it may also have some screws securing it in place. If you can't see the back of valve a mirror will allow viewing. Just a thought.
http://www2.dometic.com/5681e2be-966...e49a220e.fodoc
Old 12-05-2015, 07:26 AM   #15
Yes I found the breakdown and do not see screws so I just didn't wanna force something that should not be forced... Thank you
From Central Texas
leak
