Old 02-04-2019, 09:10 PM   #1
Boatdude62's Avatar
Under sink vents
Anyone with a 36 ckts find any other under counter auto vents? I only find one under the kitchen sink.
I知 trying to find a strange smell in the basement.
Boatdude62 is offline   Reply With Quote
Old 02-05-2019, 06:27 PM   #2
keith52's Avatar
We have a 2017 36ckts and I have only seen the kitchen sink air admittance valve. Can't recall seeing anything for the bathroom sink and shower.
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 02-10-2019, 11:09 AM   #3
I have a 2016 36CKTS. There is a second under sink vent in the bathroom. It is located through an access hole in the wall under the left side of the sink.
Steve and Cindy
2016 Cedar Creek 36CKTS
2015 Ram 3500 Laramie, crew cab
happy traveler is offline   Reply With Quote
Old 02-10-2019, 08:02 PM   #4
keith52's Avatar
happy traveler, thanks for the information. Great to know!!
Old 02-10-2019, 08:17 PM   #5
gkochel's Avatar
As Happy Traveler mentioned under the bathroom sink and to the left thru a very small hole. If you need to replace that valve at some point remove the in wall linen closet in the bedroom and then you will have very easy access to that valve to your left. After doing that I enlarged the undersink hole for easier access in the future. I have a 34RLSA and this assumes your setup is the same
2015 Cedar Creek 34RLSA Touring
2004 Silverado Duramax Crew Cab Dually
gkochel is offline   Reply With Quote
Old 02-11-2019, 09:45 AM   #6
Boatdude62's Avatar
We have a bad smell that noticeable in the basement storage. This vent is most likely the issue. The vent under the kitchen sink went out and was replaced.
How is the cabinet held in the wall? I not find any screws in the bathroom cabinet.
Old 02-11-2019, 10:57 AM   #7
The valve under the bathroom sink and through the hole on the left, is a back flow preventer valve for the black tank water pressure clean out. It is unlikely this is the culprit. If it was leaking, it would drip into the basement storage compartment and be easily detectable. The under kitchen sink valves are just rubber flappers and not very effective at sealing or stopping odor. I replace ours with a household type from Lowes or Home Depot and it has totally eliminated the odor. If it is not that valve, then it may be a leak under the basement around the tank valve(s) or connection hose which means the under belly will have to be removed for inspection and repair. Good luck.
Steve & Lee
Jacksonville, FL
2013 Cedar Creek 36 CKTS Touring Edition
2012 F350 King Ranch, Reese Elite 18 and Air Bags
Elkrun is offline   Reply With Quote
Old 02-11-2019, 12:05 PM   #8
Boatdude62's Avatar
What I just learn....on ours, the auto vent is locate right beside [left] of the pressure valve. I barely got my hand in there to change it out, but it痴 replaced with a new one. Thanks for the tip. I never knew that access hole was there. Have to wait and see if it corrects our evening smell issue.
We think the roof 360 vent is somehow plugged or restricted. That will be our next project if the smell continues.
sink, vent
