Old 07-31-2014, 12:21 PM   #1
Vac not working
Is there something i'm missing on the built in vac on my 36CKTS?. Power on and open the kick plate and nothing, tried plugging hose in and nothing. As far as I can tell all the breakers on good, is there a secret breaker somewhere?
pavetim is offline   Reply With Quote
Old 07-31-2014, 12:25 PM   #2
Is it plugged in? Is the bag section open?
1. When new our vac had the spare bags and such stored inside of it and the cover was partially open and would not come on until that cover was closed tight.
2. Ours plugs into an outlet in the front storage area just above the unit itself.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 07-31-2014, 12:29 PM   #3
yeah it's plugged in and bag is on. I'll check the door. Duh I can run an extension cord and see if it works, i'll run out and do that now.
Old 07-31-2014, 12:37 PM   #4
Nothing, guess I must somehow have a brand new vac thats bad.
Old 08-28-2014, 06:26 PM   #5
I found there is a little black lever and if you move it it comes on hope this helps
bt_1959 is offline   Reply With Quote
Old 08-28-2014, 06:41 PM   #6
Where is this lever?
Old 08-28-2014, 06:42 PM   #7
Right above where you put the hose in under the flap
Old 08-28-2014, 06:43 PM   #8
It is real tiny but I had the same problem till I played with this lever
Old 09-13-2014, 07:27 PM   #9
Did you ever get the vac to work
Old 09-13-2014, 07:44 PM   #10
MC9
CC replaced my vac at the Goshen rally. I think it is in the controller. It had a mind of it's own.
MC9 is offline   Reply With Quote
Old 11-05-2015, 11:56 AM   #11
Vac not working
Plez help me....vacuum worked awhile then nothing
mysweetmeme is offline   Reply With Quote
Old 11-05-2015, 01:26 PM   #12
Jim34RL's Avatar
Some basic troubleshooting. I know this may seem simply but this is how you trouble shut an issue.
First is the camper plugged into shore power? The vacuum only works on 110.
Second is the circuit breaker turned on for the vacuum.
Third does the floor sweep work? If so is the proper end of the hose pushed into the vacuum port?
Fourth is the unit plugged into the 110 port in the basement under the steps,behind the sliding door?
Fifth, is the vacuum cover closed tight where you change the bag?
If you have checked all of this and the vacuum is still not working than you will need to have the unit serviced.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
