Originally Posted by mysweetmeme
Plez help me....vacuum worked awhile then nothing
Some basic troubleshooting. I know this may seem simply but this is how you trouble shut an issue.
First is the camper plugged into shore power? The vacuum only works on 110.
Second is the circuit breaker turned on for the vacuum.
Third does the floor sweep work? If so is the proper end of the hose pushed into the vacuum port?
Fourth is the unit plugged into the 110 port in the basement under the steps,behind the sliding door?
Fifth, is the vacuum cover closed tight where you change the bag?
If you have checked all of this and the vacuum is still not working than you will need to have the unit serviced.
