Originally Posted by ehnewlenox
Has anyone had any experience with the Voyager WVOS713 Digital Wireless Observation System? We are considering it as an add-on to our Cedar Creek 5th wheel (with our Ford F250 Crew Cab as the tow vehicle) and are unsure about its ability to transmit consistently across the 53 foot distance between the camera and the monitor. Plan to use it primarily as a backup camera.
I have the same year and model CC as you.
My Voyager Model WVOS511 purchased from
www.rvcams.com would lock up and at times display "no signal".
Here's how I fixed it.
Purchased :
1-80" Antenna extension
Part# WVOSANTEXT
1-35' Extension cable
Part# WVOSANTEXT35
I ran the extension cable and antenna extension from the rear camera to the front cap. The cable is tie strapped to the AC and vent mounts. In between I used stick on pads to the roof that you can run tie straps through.
Since doing this my monitor has not lost the signal.
C.B.
