Old 05-14-2016, 08:07 AM   #11
I had the same problem with my 2014 21FBRS. Never hauled more than 5-10 gallons in it and always filled up at campgrounds. I had the angle Iron supports beefed up and had steel plates welded across them. I guess FR will wait until a tank causes an accident with a consequent expensive law suit.
00buck is offline   Reply With Quote
Old 05-14-2016, 08:21 AM   #12
Wolverine 1945's Avatar
Originally Posted by mnoland30 View Post
It is 3/4" metal straping with holes every inch or so. Plumber's use it to attach pipe to walls or basement ceilings.
I got ya,,, Plumbers Strap !!! I did not know it was also called Tape,,,
Plumbers Tape to me is made of Teflon !!!
Thanks !!!
Wolverine 1945 is offline   Reply With Quote
Old 05-14-2016, 08:34 AM   #13
bareftn's Avatar
I just went to safercar.gov a filed a compliant with the government, don't know if anything will come of this but if others do the same maybe forest river will do something
bareftn is offline   Reply With Quote
Old 05-14-2016, 08:37 AM   #14
Probably a good reason not to follow a TT to close going down the HWY !!!
Old 05-14-2016, 08:39 AM   #15
DDC
DDC's Avatar
Good for you that is the way these types of pending disasters should be handled.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 05-14-2016, 08:55 AM   #16
What they will do is replace it with the same soft steel angles fabricated from bent plate that LCI installed in the frame to begin with. i talked with LCI about ours and was told I void the frame warranty if I correct their design which failed lol. Screw them and their warranty. LCI made your frame and the water tank tray. It was shipped to Rockwood assembled and all Rockwood did was drop in the water tank. I suspect youll be without a camper for awhile unless your dealer just adlibs it and makes supports that will do the job. The dealer will go to Rockwood, Rockwood will go to LCI, and then they'll him haw around I suspect. I made new ones from 1 3/4 x 1 3/4 x 3/16 hot rolled angles.
I will also contact the NHTSA. This issue has to affect all 2016 and 2017 Roos. If your supports have not deflected yet just give it some time, they will.
Mr Havercamp is offline   Reply With Quote
Old 06-09-2016, 08:11 AM   #17
bareftn's Avatar
just got mine back on Monday 5/6 , dealer used tube steel to brace it up ,forest river never sent the part when they said it was shipped 5/27 by ups with no tracking number. it looks ok but I think I will change what they did.
Old 06-09-2016, 12:29 PM   #18
I ended up bracing mine from frame to frame with 1 3/4 angle iron under center of tank location.
Doug Currie is offline   Reply With Quote
Old 08-23-2016, 08:41 AM   #19
Bobaloo's Avatar
Mine looked weak a few weeks ago so I got a 2" wide ratchet strap and used rubber scraps to keep from scratching up the frame where the hooks meet the I beam. Cinch it down good in the center of the tank rail to rail and it's a little insurance policy against failure until I can permanently fix it this winter
2013 Rockwood 2504
2015 Silverado 1500 Double Cab
Bobaloo is offline   Reply With Quote
fresh water, tank, water, water tank
