Old 05-08-2014, 07:25 PM   #1
Water Filter Type on Cedar Creek
Ok I have the water filter on the rig and I didn't write it down the model of the filter when I threw it out last year - anyone have the right make/model of the filter or is it based on some standard ??
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 05-09-2014, 02:50 AM   #2
kc8lvy's Avatar
Mine was also labeled on the clear bowl of the filter housing. Mine was a Pure water filter.
Hope this helps
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 05-09-2014, 02:55 AM   #3
Mddle of the Rd Extremist
MeepMeep's Avatar
My 38FL has a KW1 filter element. Only place I could find it was thru Forest River at about $20 ea
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 05-09-2014, 08:42 AM   #4
Thanks guys that was the one!
Walter & Donna
Old 06-05-2014, 11:23 AM   #5
MeepMeep's Avatar
38FL Water filter stuck.....
Time to change the filter in our 6mo old 38FL. So I took the handy-dandy supplied filter wrench and made some grunting noises - but the darned thing would NOT budge. So I removed the mounting screws and went at it with two filter straps (one on the cup and the other on the filter housing) and twisted them in opposite - again with the required grunting sounds. After several more attempts, I put everything back, added an in-line filter and stopped using what I was told was "inappropriate language".......
I am now at the point of replacing the entire assembly, but I want to be sure I've exhausted all remedies known to the collective. HELP!!
MCPO (Retired)
Old 06-05-2014, 11:49 AM   #6
Did you have the water system off and a fixture Open? Youroo!!
Old 06-05-2014, 11:54 AM   #7
MeepMeep's Avatar
Thanks for the reply, Youroo
Yep, had the water off, kitchen fixture open.....after a fellow camper saw me struggling and advised me that the filter wouldn't budge under pressure
MCPO (Retired)
Old 06-05-2014, 07:55 PM   #8
Ours is very difficult to remove but one hand on top of the bracket and one on the wrench it does give in.
Walter & Donna
Old 06-05-2014, 11:10 PM   #9
Sometimes you have to tighten something and then it will come loose. Strange science, I know, but it works.
John
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
John Hagen is offline   Reply With Quote
Old 06-05-2014, 11:15 PM   #10
Plain Old Member
Ours comes off somewhat easy, but I plan to get rid of it all together as soon as I can slow down enough to cut / splice. To me it's in the way, and I'd rather have the filter assembly that I want.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 06-06-2014, 02:52 PM   #11
MeepMeep's Avatar
John
I did this the other day without any positive results. As a last ditch effort, decided to go "all in" and was either gonna fix it or have to replace it. So I gave the tighten to loosen method one more try and this time it worked!! Just hope it works again next time I have to change the filter.....
Thanks to all for your inputs
MCPO (Retired)
cedar creek, water, water filter
