05-08-2014, 07:25 PM
Water Filter Type on Cedar Creek
Ok I have the water filter on the rig and I didn't write it down the model of the filter when I threw it out last year - anyone have the right make/model of the filter or is it based on some standard ??
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
05-09-2014, 02:50 AM
Mine was also labeled on the clear bowl of the filter housing. Mine was a Pure water filter.
Hope this helps
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
05-09-2014, 02:55 AM
Mddle of the Rd Extremist
My 38FL has a KW1 filter element. Only place I could find it was thru Forest River at about $20 ea
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
05-09-2014, 08:42 AM
Thanks guys that was the one!
Walter & Donna
06-05-2014, 11:23 AM
38FL Water filter stuck.....
Time to change the filter in our 6mo old 38FL. So I took the handy-dandy supplied filter wrench and made some grunting noises - but the darned thing would NOT budge. So I removed the mounting screws and went at it with two filter straps (one on the cup and the other on the filter housing) and twisted them in opposite - again with the required grunting sounds. After several more attempts, I put everything back, added an in-line filter and stopped using what I was told was "inappropriate language".......
I am now at the point of replacing the entire assembly, but I want to be sure I've exhausted all remedies known to the collective. HELP!!
MCPO (Retired)
06-05-2014, 11:49 AM
Did you have the water system off and a fixture Open? Youroo!!
06-05-2014, 11:54 AM
Thanks for the reply, Youroo
Yep, had the water off, kitchen fixture open.....after a fellow camper saw me struggling and advised me that the filter wouldn't budge under pressure
MCPO (Retired)
06-05-2014, 07:55 PM
Ours is very difficult to remove but one hand on top of the bracket and one on the wrench it does give in.
Walter & Donna
06-05-2014, 11:10 PM
Sometimes you have to tighten something and then it will come loose. Strange science, I know, but it works.
John
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
06-05-2014, 11:15 PM
Plain Old Member
Ours comes off somewhat easy, but I plan to get rid of it all together as soon as I can slow down enough to cut / splice. To me it's in the way, and I'd rather have the filter assembly that I want.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
06-06-2014, 02:52 PM
John
I did this the other day without any positive results. As a last ditch effort, decided to go "all in" and was either gonna fix it or have to replace it. So I gave the tighten to loosen method one more try and this time it worked!! Just hope it works again next time I have to change the filter.....
Thanks to all for your inputs
MCPO (Retired)
