11-02-2016, 01:57 PM
Water heater
We have a 2016 33ik and the water is not very hot. Any ideas if and/or where to adjust the temperature on the water heater?
11-02-2016, 02:07 PM
Most water heaters do not have a temp adjust, but check to insure that the water heater bypass is not in bypass mode( valve should be perpendicular to water line). Also make sure the faucets in the outside shower are both off.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-02-2016, 02:08 PM
Most common causes:
1. WH bypass valve on
2. Outside shower valves on
Most RV water heaters have fixed temperatures.
11-02-2016, 02:10 PM
Do you know the model # of your water heater?
It helps to post this information when asking about an item where there are many different models/manufacturers of.
With that said, unless it is an on demand heater, they are usually not adjustable.
Most of the 'my water is not hot enough' issues come from the bypass valves on the water heater being turned incorrectly allowing mixing of hot and cold water -or- an outside shower where the valves are open and the shower head is shut off allowing mixing of hot and cold water through the shower head.
11-02-2016, 02:42 PM
I would agree with bikendan check the bypass, my son needed help winterizing and when I started to show him how I found the bypass was already on. When I showed him he asked what it did then he said probably why I wasn't getting really hot water. Next year I will go set it up for him and see if it helps.
Think about things before you do them make life easier not harder.
11-02-2016, 02:49 PM
Is this a tankless water heater or a traditional water heater?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
11-02-2016, 04:03 PM
Sorry guys, is a 10 gallon water heater, not tank less. Will check the two lines, thanks
11-02-2016, 04:31 PM
All three lines behind the hot water heater are pointed down the lines. Is that how they should be? I checked and the outside shower lines are off.
11-02-2016, 04:34 PM
Water heater
11-02-2016, 06:19 PM
If you are talking about the valve handles being inline with the water lines the one water line that is connected between the other two should have its valve handle perpendicular to that line. The other two are correct for normal operation. When you winterize just reverse the configuration of all three. That will by-pass the water heater.
11-02-2016, 06:23 PM
Take a picture of the lines. The bypass should make a tee when it's closed and to get hot water you need to close it. Otherwise it acts as a mixer valve and cold mixes with hot so you get only warm water.
11-02-2016, 06:35 PM
Ok, so top valve handle in line, middle perpendicular, bottom in line? Sound right?
11-02-2016, 06:36 PM
Maybe this will help...
11-02-2016, 06:41 PM
Awesome, not good with big words lol. I did what you said and it worked, thanks. No more Luke warm showers. Dealer said all lines open.
11-02-2016, 06:48 PM
This is a very common occurrence, which is is why we keep this sticky in the plumbing section, you might can bookmark for next time, to help:
http://www.forestriverforums.com/for...st-103381.html
2011 Flagstaff 831 RLBSS
11-02-2016, 09:22 PM
Check this out from another post. This person showed it very well.
http://www.forestriverforums.com/for....php?p=1338602
Tom
2016 Ford Power Stroke F350 Lariat Crew Cab Long Bed Dual Wheel
2015 Cedar Creek 38RD Hathaway Edition
