I have a 2014 Silverback 29RE and don't want to run the water heater on propane. I assume it's water & electric because I found the switch outside under the burner tube to turn on the electric, but every time we take a shower, the propane flame turns on. I have pressed the reset button but don,t know what to do next?
Shut it off at the control panel with the switch labeled Water Heater.
It doesn't use much propane and your showering experience shows it is needed for quicker recovery than when it's on just electric.
There are two completely separate heating systems.
The switch (and DSI fail light) inside is for DC/Propane and the black one outside is for AC (shore power).
Remember to switch that one off too when you are not using it to heat the water with shore power. Easy to forget and drain the water heater; destroying the heating element.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
On mine the breaker only controls the electric. If only wanting to run propane leave it off and turn on the switch on control panel.
Waiting for a new gas valve and probably order a new module board. Not getting any current to the wires at the valve. Have to wait and call to see if I fried it while testing.
Learning can be expensive.
Water heater has a 12 volt 15 amp fuse in the power center.
Also examine the thermostats for damage; the one for the gas system is on the right under the rubber cover.
