Old 03-09-2014, 01:39 PM   #1
water heater switch
How do I keep my water heater electric only? I don't need propane right now, have shore power. Also what goes into what grey tank?
pavetim is offline   Reply With Quote
Old 03-09-2014, 01:41 PM   #2
Make sure it is full of water and just don't turn the inside wh switch on (DSI) which is the propane side.
Old 03-09-2014, 01:54 PM   #3
wmtire's Avatar
If you have the Suburban brand water heater, with an electric heating element, this may help you:
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-09-2014, 04:09 PM   #4
Former Full Timer
Duckogram's Avatar
Pavetim,
To keep your WH on electric only you must resist the urge to
push the water heater switch to the on position in the control center
located above your broom closet.
The gray tank question is a trick question. You have 2 gray tanks,
The forward tank is where your washer, bathroom sink and shower dump.
The rear tank is where your galley dumps.
The correct answer to your question is; gray water goes into both gray tanks.
Hope this helps.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
heater, water, water heater
