We have same unit. Under the sink, on the right side, where the drain pipe from the sink goes toward the wall, there is a T with a pipe going up with a vent baffle at the top. That may if not working correctly and could be where the water is coming from, that's the first place I would check. If the shelf and floor is wet, bingo you found the problem and it is easily fixed. The galley tank is right below the sink, oven and refrigerator. Between the gas oven and the refrigerator, about 2 feet from the wall is where the drain pipe goes through the floor into the galley tank. The drain pipe as it goes along the wall behind the oven, vents up and out the roof. It may be that one of the couplings are leaking, cracked, or etc. Turn off the LP , bleed the gas off, then disconnect the oven. Pull the stove top/oven to get to it. If it's none of the above, sorry it most likely is the tank could be cracked or pipe leaking. You'll need to pull the under panels toward the rear of the 5th wheel from the drop down by the steps of the back door, to just before the front door (over the axles). If it is the tank, the insulation will be wet, but not just by the wall, it should soaked, by what you posted.
Hope this helps and God bless,
Mike
Mike and Judy
Wherever we are parked is our home
2009 - 36RD5S
2007 - Dodge 3500 6.7 Cummins
May God bless
WA8MRU
