Old 10-27-2013, 03:22 PM   #11
Bogey3025's Avatar
Originally Posted by OldCoot View Post
Well, logic tells you it has to be the regulators, either they are junk, installed wrong or not adjusted. Can't be anything else.
On to the hose.. That's how we told to install.
Bogey3025 is offline   Reply With Quote
Old 10-27-2013, 04:03 PM   #12
Ford Idaho's Avatar
Are all the water valves in the full on off position?
Is there a water filter someplace?
Old 10-27-2013, 04:23 PM   #13
Owner/Operator
RodeoGeorge's Avatar
At which end of the hose? The end that connects to the water supply, or the end that connects to the RV?
If the regulator is on the end that connects to the city water supply, that blows my theory.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 10-27-2013, 04:49 PM   #14
Bogey3025's Avatar
To the water supply...
Old 10-27-2013, 04:52 PM   #15
Bogey3025's Avatar
Originally Posted by Ford Idaho View Post
Are all the water valves in the full on off position? Is there a water filter someplace?
Yes.
Yes there is water filter
Old 10-27-2013, 04:53 PM   #16
If you hook up everything and run it OPEN (Not Con to RV is there flow? Youroo!!
Old 10-27-2013, 05:13 PM   #17
Ford Idaho's Avatar
Bypass it!
Old 10-27-2013, 05:39 PM   #18
Rupkin2's Avatar
I'm with Ford Idaho, either get rid of it or by-pass it. (the filter)
You really don't need it, seems everyone drinks bottled water anyway.
the size of the microns on the filter will defiantley lower the humph of the pressure as I found out on an earlier trailer I had.
When I used my regulator it was attahced to to city faucet to which I attached my water hose that went to the city connection on the trailer.
Got rid of that also, pressure was to low, I had a 60psi.
Supposedly the pipeing is good to 100psi, I have yet to come across a city line higher than 80psi, thats only me anbd my areas though.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 10-27-2013, 05:50 PM   #19
The filter might reduce pressure, but that is not the reason for this problem if he has pressure without the regulator. The regulator is the problem. Needs adjustment maybe?
Old 10-27-2013, 06:40 PM   #20
Blaster 84's Avatar
You may have a faulty regulator and the one you purchased one is also faulty. That's been know to happen on more than regulators.
2013 F150 XLT, SuperCab, Ecoboost; Rockwood 8285WS
Nights camped:
2014 - 57
2015 - 91
2016 - 171
2017 - 107
Blaster 84 is online now   Reply With Quote
