Old 10-27-2013, 07:39 PM   #21
Former Full Timer
Duckogram's Avatar
Wow! An awful lot of opinions from the Creeker Envy crowd...
http://youtu.be/xCc-RWIp7XU
There are two valves that control the water flow. One is the fresh/city. It is possible for that handle to slip if the screw loosens. Check this by disconnecting the city water, turn on your pump and see if you get cold water from your utility hose faucet. The second is on the bypass panel. It the one on the bottom. It should be horizontal (open). I am assuming that you: have water in the tank, have visually inspected the filter, have left the city water connected long enough to fill the water heater, have not heard water running on the ground, it is above freezing where you are located and you have tested the regulator for functionality. You might want to consider getting a real pressure regulator down the road. 50 lbs is a realistic setting. While you are at it, the OEM filter cartridge has a 1gpm flow rate. You will notice better shower and faucet functionality if you go to a 5gpm cartridge. I use a carbon + cartridge that improves taste and eliminates odor as well. They are standard 2.5"x10" and can be found easily and cheaper. Hope this helps
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 10-27-2013, 10:13 PM   #22
Originally Posted by youroo View Post
If you hook up everything and run it OPEN (Not Con to RV is there flow? Youroo!!
Can you reply to this? You keep saying(Everything is hooked up like before the dealer had it),disconnect at the F/W entrance on your unit,Hold that end,turn on the Water Supply! Do you have water flowing out NOW? Youroo!!
Old 10-27-2013, 10:29 PM   #23
Don't know where you get this envy junk, we're just trying to help.
Old 10-27-2013, 10:40 PM   #24
No,he is Envious of us having Water! Youroo!!
Old 10-27-2013, 10:41 PM   #25
Guess so, us with our el cheapo units that work.
Old 10-29-2013, 07:54 PM   #26
Bogey3025's Avatar
What's up with the "envy junk"? Not sure I get that.. As for the water problem.. After 3 different regulators... We have water, pressure is better.
As a side note... Service at Camping World, Avondale AZ is the worst. We purchased our rig in Feb, and they have had three changes in service managers, they have lied several times always putting the blame on Forest River for not sending out the necessary parts. Jeff and Jeffery from Forest River have been outstanding. We are very happy with our Silverback and the service ONLY provided Forest River, AND the outstanding knowledge provided by everyone on this site. So thank you for always lending a helping hand...BTW...One gentleman mentioned removing the filter... We did that and that DID increase our pressure.
Bogey3025 is offline   Reply With Quote
Old 10-29-2013, 08:13 PM   #27
I have the same problem with water psi, took psi regulator off, still low psi. next I will remove my water filter and see if that will help. What psi should be on the trailer water lines?
Gee Whiz is offline   Reply With Quote
Old 10-29-2013, 08:25 PM   #28
I set mine at 45 psi and still have the filter in use. No problem with pressure.
Old 10-29-2013, 08:28 PM   #29
Fulltime family RVer
Same PSI here.
Old 10-29-2013, 08:45 PM   #30
bubbles's Avatar
Just a note. Pull your fawcet aerators and check for fine sand build up. Will have an affect with lower pressure input to system. Not necessarily what's causing this issue.
