Old 12-30-2015, 07:53 AM   #11
Homebrew's Avatar
Did you look behind the panels in the basement storage area?
I have to remove some of these panels to winterize and get to valves and the pump.
My pump is behind the hot water tank
Homebrew is offline   Reply With Quote
Old 12-30-2015, 08:23 AM   #12
My pump is in the basement behind the docking station.
I have to have a fair amount of water in the tank to get mine to work and with a very large water heater it might take a while to fill it up before water will come out.
Are you able to hear the pump run when you turn it on?
If not I'd make sure you have power to it, if you hear it I'd make sure you have water to it.
Go from there, while pumps do go out it's not that often.
DKRITTER is offline   Reply With Quote
Old 12-30-2015, 11:50 AM   #13
I guess that you're saying that it doesn't run at all??? If it runs, you can listen for the sound of the pump running and normally find it that way.
My guess is that you access it from your storage basement up front. You most likely have a false wall in the basement that divides the storage area up front from the "utilities" area toward the middle of your trailer. Remove one of those panels that make up the false wall just aft of your cargo doors and you'll probably find the pump. I'm guessing it will be on the drivers side (curb side) of the trailer.
bruceatlam is offline   Reply With Quote
pump, water, water pump
