Old 12-29-2015, 01:07 PM   #1
Water pump
Happy holidays to all my FR family.
I have a 2014 FR 5th wheel (37fl) and I'm needing to replace water pump.
Has anyone done this. Where is it located and degree of difficulty.
I think it went south because it just won't siphon water up to faucets.
Thanks a head of time.
Happy new year
Craig
craigi is offline   Reply With Quote
Old 12-29-2015, 02:09 PM   #2
Pickin' & Campin'
Not being a jerk here but if you don't know where it is located and don't know how to change it... are you sure it is bad? Replacing a pump because you 'think it's fried' doesn't seem like a logical diagnosis.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 12-29-2015, 04:34 PM   #3
Not a problem. I certainly will not replace if I find it to be working I will not replace.....now that would be "stupid". I just need to locate and get a visual on it and go from there. I don't really know for sure where it's located.
It is not siphoning and I've opened all the faucets for long periods of time and nothing.
Thanks for the replay 5picker.........happy trails
Old 12-29-2015, 04:37 PM   #4
A32Deuce's Avatar
Is there a valve for winterizing to pull in antifreeze? I don't know if this would help, but it should be fairly close to where the FW tank is, maybe pass-side.
A32Deuce is online now   Reply With Quote
Old 12-29-2015, 04:40 PM   #5
I'll look........thanks
Old 12-29-2015, 04:42 PM   #6
A32Deuce's Avatar
I don't have a 5er, but my pump is in the same location as the filter and next to bottom of FW tank. Hope this helps.
Old 12-29-2015, 04:44 PM   #7
A32Deuce's Avatar
By the way, mine blew the fuse at the pump and didn't work. Thought I NEEDED A PUMP, replaced fuse all good. CW didn't know there was a fuse there!
Old 12-29-2015, 04:48 PM   #8
Flybob's Avatar
Did you have your unit winterized? If so, the winterizing valve may still be in the service position. If so it will only suck air. If the unit was not winterized. Turn it on and listen you should be able to hear it vibrating. Do not leave on for extended periods with no water.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-29-2015, 05:19 PM   #9
Left Coast
look for city water input.....mine is in very bottom cab. behind false wall.
Old 12-29-2015, 11:22 PM   #10
Duckogram's Avatar
I believe it is behind your docking station.(pictured below) Stick you head in the compartment and you should see a black plastic curved panel. The panel pulls out from one side. Its been years since I looked at it so my memory may not be as accurate as I would like.
ILB
pump, water, water pump
