Old 07-06-2014, 11:55 AM   #1
Bogey3025's Avatar
Water pump continues to run all the time....
We have a 2013 Silverback 29RE while dry camping our water pump has started running all the time and draining the battery.
We shut it off and when we turn it back on it starts running again??
Bogey3025 is offline   Reply With Quote
Old 07-06-2014, 12:17 PM   #2
Love My Sunseeker
DXSMac's Avatar
Had that problem. Turns out, water pump went poof. I was out of warranty, but I had it fixed in a small town mom n pop RV place in Utah for less than $200.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 07-06-2014, 12:45 PM   #3
Three potential causes: 1) Either the pressure switch that's supposed to turn it off has failed, OR 2) the pump isn't putting out enough pressure so it just keeps running OR 3) potentially the check valve is stuck open and not holding the pressure (this last one would be evidenced by the pump shutting off and immediately restarting).
Most probably, as with DXSMac's problem, is #2 - the pump failing.
1988 Coleman Sequoia - popup (1987-2007)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 07-06-2014, 01:21 PM   #4
fonzie's Avatar
or you are out of water in your fresh water tank.....
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 07-07-2014, 11:41 AM   #5
Former Full Timer
Duckogram's Avatar
...or you have a leak...
The recipe for perpetual ignorance is:
Be satisfied with your opinions
and content with your knowledge.
Elbert Hubbard
Old 07-07-2014, 04:30 PM   #6
Had a similar problem when our pump developed a vacuum block or something. We turned off the pump, opened a faucet and let the pressure bleed off then tried again and it was fine.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2014 Days Camping: 35
38FLCamper is offline   Reply With Quote
Old 07-07-2014, 09:52 PM   #7
A new water pump isn't expensive -- don't pay to fix the old one. I bought one on Amazon for well less than $100. Barring one of the obvious problems listed above, I'd just buy a new pump.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 07-07-2014, 09:56 PM   #8
B and B's Avatar
I just replace mine under warranty. The check valve was defective, would run several time about once a minute after you used water. It would eventually shut off.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
pump, water, water pump
