Old 04-08-2014, 07:01 PM   #11
Originally Posted by danno2u View Post
I had the same problem once. I tried everything but the pump wouldn't prime. I pulled the pump and dismantled it looking for anything wrong with the diaphragm or lines. Everything looked good.
Then I blew into the feed line to make sure it was clear to the tank. It was. Next I sucked water up the feed line by mouth (just like siphoning gas for an old car). When I got a mouthful of water, I quickly reattached the line. From then on, everything worked fine. I'd try some of the other suggestions first, but priming by mouth then reattaching the line worked for me.
I will try that too, I have sucked enough gas and it sure don't taste good
spock123 is offline   Reply With Quote
Old 04-10-2014, 07:15 PM   #12
I don't know what I did but pump is working again, I did something today but what I don't know, but it works
Old 04-10-2014, 08:27 PM   #13
TURBS's Avatar
Air in your system and or wh will cause this problem.
TURBS
Sabre owners united!
pump, water, water pump
