Old 06-29-2014, 12:25 PM   #1
Water seeping
Driver side basement door collects water on top and bottom edge so when you open the door you get a small wet splash into the basement compartment.
Suspect bottom on hing side is gathering enough water to go over the top of the rubber seal.
All thoughts on this subject appreciated.
Joe Wakeman
2012 36RE
2013 2500HD Duramax
jwakeman is offline   Reply With Quote
Old 06-30-2014, 09:20 PM   #2
Plain Old Member
I don't have the answer, but my basement doors pretty much do the same thing. They don't leak, but do collect water in the areas you mentioned and when opening a little will get inside. I've wicked the water off the top of the door before opening, and all was dry inside.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
water
