Old 04-18-2014, 08:22 AM   #1
WaterPur Filter
I have a WaterPur filter that takes a KW1 filter. The local CC dealer doesn't have any ist here a replacement that works other than the filter from WaterPur? Thanks
Steve & Lee
Jacksonville, FL
2013 Cedar Creek 36 CKTS Touring Edition
2012 F350 King Ranch, Reese Elite 18 and Air Bags
Elkrun is offline   Reply With Quote
Old 04-18-2014, 08:28 AM   #2
Orion's Avatar
Nope.
I just use an inline filter on the hose so I don't have to worry about their proprietary filter. Thinking about replacing the Waterpur with a unit from Home Despot...
Orion is online now   Reply With Quote
Old 04-18-2014, 08:37 AM   #3
Herk7769's Avatar
I used the ones from Home Depot/Lowes for a while. (Before I removed it completely and installed an expansion tank in its place).
Just so you know, the "correct" one has a larger pore size so it does not reduce the water pressure as it filters. If you try to use the same size filters from the home store, ONLY buy the "sediment" filters and never the ones that remove impurities. The pore size is so small they clog almost immediately at campgrounds that use well water.
I now use the Wal-Mart exterior filters and put a new one on at the start of season.
ID:	50146   Click image for larger version
Name:	6 June 2009 025.jpg
HAM CALLSIGN - KC3FFW
Old 04-18-2014, 08:40 AM   #4
Ford Idaho's Avatar
Originally Posted by Orion View Post
Nope.
Despot?
@OP
Replace the one you have with one like this.
GE Clear Whole House System-GXWH20S at The Home Depot
Old 04-18-2014, 09:45 AM   #5
Thanks for the replies. I will get an external from WalMart. I like the idea of adding an expansion tank in place of the existing "internal" filter system............it'll cut down on pump cycles when I'm on the tank supply. Thanks again.
Steve & Lee
Jacksonville, FL
Old 04-18-2014, 09:49 AM   #6
Herk7769's Avatar
FYI I later upgraded the small Shurflo tank with a 2 gallon one.
Since THESE photos were taken, I added a shutoff valve to keep RV antifreeze out of the pressure vessel. After draining the system; I close the valve before adding the antifreeze.
ID:	50169   Click image for larger version
ID:	50170   Click image for larger version
ID:	50171   Click image for larger version
Old 04-18-2014, 12:01 PM   #7
Thanks Herk7759,
I like the system.....since I moved from South Dakota to Florida last year I'm hoping antifreeze is a thing of the past!
Steve & Lee
Jacksonville, FL
water
