Old 05-14-2016, 07:45 PM   #1
I have a 38FB2, with the Trail Air pin, and a curt 24 hitch in the truck. I have towed it about 700 miles, and ever since picking it up, I have noticed a slight sway when pulling, I tow from 60-65 on the freeway, closer to 63 if I had to average it out. It sets pretty level, the bag on the hitch is where it should be, as far as the arrows are to be. Actually it could have used a few more pounds coming home today. Anyone else have this problem, or maybe some clues to help it not to sway. Thanks
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
wls is online now   Reply With Quote
Old 05-14-2016, 09:13 PM   #2
Check tire pressures and make sure they are at the max bot truck and trailer. If the trailer is nose high make the proper adjustments to level it out.
If you have a full fresh water tank or lots of weight in the back of the trailer try to eliminate that and see if it helps. Any of all of these things should help.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 05-22-2016, 07:41 AM   #3
I would start by getting the rig weighed. You may be too light on the pin. Pin weight should be about 20% of total trailer weight.
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is online now   Reply With Quote
