Old 07-05-2014, 09:33 PM   #1
We have a 2013 Cedar Creek CKTS and are having problems with our 15,000 btu Dometic a
Cowboy52 is offline   Reply With Quote
Old 07-05-2014, 09:39 PM   #2
Our air sometimes it puts out warm air then it runs fine then sometimes when it shut down 30 seconds latter it comes on a runs for 30 seconds then shuts off for 30 seconds and starts again had anybody else had this problem and what did you do to fix it !
Old 07-05-2014, 09:54 PM   #3
Plain Old Member
Sounds like you either have control box or thermostat issues. I've had a couple get "confused" and had to be replaced. In our Forester, the AC had erratic behavior and couldn't decide what to do. Replaced control box and t-stat in it. In our Silverback, recently replaced the control box as it go to clicking a bunch like it couldn't decide what to do. Replaced, now all works fine, for now.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-05-2014, 10:05 PM   #4
We've had ours worked on twice said they couldn't fine anything wrong I think they just turned it on and just let it run didn't stay inside to see what's wrong thanks for your response
Old 07-05-2014, 10:19 PM   #5
Plain Old Member
I took a video with my phone when the AC was acting up, that way I had PROOF that it was doing what I said it was doing. As usual, the dealer couldn't replicate the problem, but, had watched the video and replaced the control box.
Old 07-05-2014, 10:32 PM   #6
Evereddie's Avatar
While it sounds like a component acting up it could be simple. Is there an air vent blowing right on the thermostat? That could cause it to short cycle. The short cycle could also cause it to start up when the compressor has not cycled through and cause warm air to flow for a while.
Evereddie is offline   Reply With Quote
Old 07-06-2014, 05:33 AM   #7
ret2006's Avatar
I had a problem with my A/C's short cycling like every three or four minutes. I replaced the Dometic Comfort Control 2 thermostat and that did the trick. These thermostats have a 1 and 2 degree on/off set point differential ONLY in the Furnace heat mode, not the cooling mode. Wish they would put a good Honeywell thermostat in these units, it would solve a lot of problems like this. The Dometic Comfort Control 2 thermostats are cheap made. If it is not your thermostat then it is in the A/C.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 07-06-2014, 06:45 AM   #8
Plain Old Member
What's bad is the comfort control 2 is the cats meow compared to what the silverback has.
Old 07-21-2014, 08:47 PM   #9
Old 07-21-2014, 08:48 PM   #10
Well they put a new board in our AC and it works great now !
Old 07-21-2014, 09:00 PM   #11
Plain Old Member
Problem solved. Same thing ours was, in two different RVs. Glad all is working now.
Old 07-21-2014, 09:03 PM   #12
We had it checked out twice they said there was nothing wrong I called shady pines what it was doing I told them to send me the board so they did and it fixed it !
Old 07-22-2014, 03:35 AM   #13
ret2006's Avatar
What is the board that you replaced in your a/c? Part Number? Can you replace it yourself? Just in case I start having trouble again.
Thanks,
Old 07-22-2014, 12:10 PM   #14
Plain Old Member
When you remove the return air grill, it's staring right at you. Silver box with all the wires coming in / out of it. Should have information on it. Pretty easy to change as long as you remember what goes where.
Old 07-22-2014, 04:32 PM   #15
I don't know what the part number is if you need one it's $145.95 just take pictures of it and make sure all power is off !
Old 07-26-2014, 11:52 AM   #16
Well there going to replace our AC unit it quit kicking on and off but it's still putting out warm air !
Old 07-26-2014, 06:21 PM   #17
Plain Old Member
It happens. At least you're getting a new one, and you aren't out the $1000 plus out of pocket yourself.
Old 07-26-2014, 07:43 PM   #18
A lot of people are having trouble out of there AC I think they should have a recall on them if I haven't stayed on them about ours we would be out that money you pay good money for a Rv !
Old 07-26-2014, 07:47 PM   #19
Plain Old Member
I've never been a fan of the Dometic's since they swapped to the digital thermostat / newer design. I've had too much trouble with them. Personally, I prefer the Coleman's, but that wasn't an option.
2013, 500, cedar creek, dometic
