Old 12-27-2015, 08:40 AM   #1
JohnF's Avatar
Weber Electric Grill
I am considering a Weber Electric Grill for our camper. It looks like it pulls 13 amps on high. I am assuming the exterior outlets on the campers are rated at 15 amps. So this should work....correct?
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is online now   Reply With Quote
Old 12-27-2015, 08:58 AM   #2
As long as nothing else is drawing on that circuit, sure will.
Karl4Cat is offline   Reply With Quote
Old 12-27-2015, 09:07 AM   #3
If running the A/C put your hot water water on gas while cooking. You can also get a 14 gauge extension cord and plug directly into the pedestal, if a 15 amp outlet is there.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 12-27-2015, 02:09 PM   #4
CC75's Avatar
I use a webber electric grill, connected to heavy duty extension cord from the power pedestal on the 20Amp circuit. I always check to make sure the cables do not get hot. Have not had any issues. I do not like plugging it into the camper.
CC75 is offline   Reply With Quote
Old 02-14-2016, 07:59 AM   #5
ScottAndKim's Avatar
Me to but be sure you have a 10g extension cord for power
Kim and Scott.
Charlie,Hank,and Tater our dogs.
Live and Learn
2016-6 days camping so far
Live and Learn.
Camping Days in 2016=2 so far
ScottAndKim is offline   Reply With Quote
Old 02-14-2016, 08:09 AM   #6
JohnF's Avatar
I ended up with their small gas grill and an adaptor for the camper propane tanks.
Ohio
2015 Ford F-350
4WD SRW Diesel
Old 02-18-2016, 02:31 PM   #7
Busybeavers's Avatar
A 15 amp circuit is only rated for 80% of that, 13 amps... I would never plug anything in that uses that high of rating into a camper.. You are better off using a 10 ga. extension cord in the power ped. Some of them have 20 amp receptacles in them and that would be so much better. Besides if you blow a circuit, you are better blowing the campgrounds and not your RV's.
Just me personal and experienced opion.
Busybeavers
2016 CC Silverback 29RE
2012 GMC 2500HD 4x4
Crew/6.5 Bed
Pullrite Superglide
Duramax/Allison
Busybeavers is offline   Reply With Quote
Old 02-20-2016, 05:44 AM   #8
Been there, done that! High amp electric "stuff" is not family friendly in an rv. I finally went back to my small Weber charcoal grill. Throw it together 20 minutes b4 cooking and works like a champ.
SilverbackMel is offline   Reply With Quote
Old 02-20-2016, 06:27 AM   #9
The_Rhino's Avatar
Our TT is only 30A so this Spring I plan to add a 2nd 30A circuit that will power a 2nd A/C and 20A outlets for indoor & outdoor grills. It's going to have a 30A plug & 30A wire going to the pedestal. I will then use adapters at the pedestal depending on whether I have 50A/30A or only 30A/20A... This way the weakest point in the circuit is at the pedestal & not my TT...
Turbs added a 2nd circuit & posted pics somewhere on this forum...
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2017-31
2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 02-20-2016, 06:53 AM   #10
davel1971's Avatar
good choice. I've had one for a few years now and love it. Sometimes I use adapter and tank, sometimes I use the disposable cylinders just because it's easier. Cylinders are cheap at Walmart.
David & Lynn
electric
