Old 04-27-2019, 09:41 AM   #1
CC75's Avatar
Weboost on TV Anetenna
Has anyone attached the weboost Omnidirectional antenna onto the TV antenna?
I have the kind of TV antenna that cranks up, with a rotational adjustment inside the trailer. I am wondering if the reception of one signal will interfere with the reception of the other signal, especially if I press the tiny little TV antenna booster button.
Secondly, has anyone used the pre-wired satellite connection to carry the weboost cell signal from the outside to the inside of the rig?
CC75 is offline   Reply With Quote
Old 04-27-2019, 02:25 PM   #2
I would not as the aluminum in the head & mast would most likely act as a reflector and turn a omnidirectional cell antenna into a somewhat directional one at best. Keep in mind you must have at least 20' of horizontal separation between in the inside & outside antennas or you will have problems (internal oscillation).
I have mine attached to the rear ladder.
Yes works just fine. i installed mine that way 2 seasons ago.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
