Old 11-08-2017, 08:46 PM   #1
Weight limits on 3/4 ton truck
Does anyone have an opinion on this question. I have a 2016 F-250 Super Duty, we currently pull a forest river crusader that has a GVWR of 10037 lbs. Looking at a forest river cedar creek that has a GVWR of 14000 lbs. Is the extra weight a problem with a 3/4 ton truck? Any opinions will be welcomed
golfaholic06 is offline   Reply With Quote
Old 11-08-2017, 08:50 PM   #2
Who Dares, Wins
doc73's Avatar
Where you will get into trouble is when you start looking at your payload. The pin weights on many 5ers quickly eat up that precious 2500 (more or less) lbs of payload.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 11-08-2017, 08:53 PM   #3
florabama's Avatar
The pin weight will be in the neighborhood of 2800+ lbs. So not being familiar with this particular truck's specs I do believe you would not have much if any remaining cargo carrying capacity after adding a couple of people, a hitch, a cooler or snacks and maybe a dog or two.
Cedar Creeks really need a 1 ton truck IMHO.
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=61
Nights Camped: 2018=25
Nights Camped: 2019=12 | Booked=6
florabama is offline   Reply With Quote
Old 11-08-2017, 09:03 PM   #4
Multi-Slacker
There should be a sticker on the driver's door frame that will state the limits for that truck as shipped from the factory. Add-ons such as running boards, bed liners caps, etc. will reduce those limits
Safe Travels
CurtPutnam is offline   Reply With Quote
Old 11-08-2017, 09:27 PM   #5
clr
I towed a 32 foot 5th wheel with a 2000 F250 super duty with a v10 engine that weighted about 9200 loaded. The truck did fine with that load but going up steep mountains and such the engine would roar. I currently pull a 40 foot Sanibel very similar to the cedar creek and when loaded I place about 3000 pounds pin weight on the truck. Currently I use a F350 dual wheel diesel engine 1 ton truck. The 1 ton truck handles the 5th easily.
There is no way my old F250 would be able to handle the 40 foot trailer.
As others have said read the sticker on the driver door frame to see what your exact truck is capable of handling. Also the weights in the book are for the basic model with no options every option adds weight to the unit. I have seen CC owners on the forum state that their basic unit had a 3700 pound pin weight prior to placing anything in the unit.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 11-08-2017, 10:10 PM   #6
KMP44's Avatar
Originally Posted by golfaholic06 View Post
Does anyone have an opinion on this question. Any opinions will be welcomed
A better question may end up being does anyone not have an opinion?
You didn't say if your truck is gas or diesel, as that will make a big difference in payload. That's what the whole thing will probably boil down to is payload.
3/4 tons are tricky because they are similar to 1 tons, but by definition are limited to 10,000 GVWR. So your payload sticker is limited by that max GVWR even if all the mechanical parts are capable of more. I'm more familiar with Fords than other brands, but on the Ford truck forums there are endless debates and arguments about whether the 250 is the same truck as a 350 just with a lower GVWR and payload sticker. I think some physical differences have been verified, but they aren't drastic. So then the opinions and speculation start. I know I marvel at some of the monster 5th wheels I see going down the road behind 3/4 tons. They look fine but you gotta believe they are way over the payload sticker.
Start with a payload calculation to compare your truck's payload with the pin weight plus passengers and gear and see where you are at and then go from there.
And hopefully when all is said and done you still welcome our collective opinions...
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
KMP44 is offline   Reply With Quote
Old 11-08-2017, 10:21 PM   #7
WFD
Thinking before you pull the trigger on that trailer you may want to go truck shopping!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-08-2017, 11:23 PM   #8
I think a 14,000 lb fifth wheel will be too much forF250
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 11-08-2017, 11:41 PM   #9
BT,DT and it aint pretty. Current CC scales at 13,500 pounds and carries a scaled pin weight at 3,500 pounds. Started with a 2500, could not wait to get rid of that and get the correct tool. My 3500 dually pulls like a dream and handles the mountains of the far west much better than the overloaded 2500 ever did.
donniedu is offline   Reply With Quote
Old 11-08-2017, 11:58 PM   #10
B and B's Avatar
I had a F250 and Traded for a F 350 Went from CCC of 2300 lbs to 3800 lbs and crew cab too boot.
F250 is not enough truck for 14,000 GVRW. I have a 16,000 lb Heartland Bighorn with a pin 3000 lbs loaded so I am within specs. Still have CCC for people and fuel and maybe some firewood.
Old 11-09-2017, 12:05 AM   #11
Need following info so everyone here can give better suggestions:
*Cab/bed configuration
*engine/trans
*axle ratio
*which tow package/suspension package
*cargo capacity from tire sticker on door jamb (i just learned that from here a *few days ago, ha!)
*2wd or 4wd
*airbags?
*your truck's GCVWR
*your truck's rear GAWR
IslandVic is offline   Reply With Quote
Old 11-09-2017, 05:36 AM   #12
Rest and Relax's Avatar
Whatever you are comfortable with weight and trucks have been debated to death on this forum imho.
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
Rest and Relax is offline   Reply With Quote
Old 11-09-2017, 06:33 AM   #13
Neighbor has been pulling a 38' Montana...just south of 15000# with 2004 Silverado 2500HD diesel for almost 10 years now. Two 8000 mile trips thru the Northwest and he's had zero problems.
TheWolfPaq82 is offline   Reply With Quote
Old 11-09-2017, 07:36 AM   #14
Insert witty title here
Here are how my numbers would work with a 5th wheel.
Truck: Chevy Silverado 2500HD Diesel
Cargo capacity: 2500lbs
Weight of passengers and cargo: 1000lbs
Leftover capacity for tongue / pin weight 1500lbs
Assuming 20% 5th wheel pin weight, the HEAVIEST 5er I can tow safely weighs 7500lbs
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 11-09-2017, 07:58 AM   #15
That seems low. My 2014 Jimmy will pull 13,000 loaded. Crew cab even.
Old 11-09-2017, 08:14 AM   #16
THank you all for the response, greatly appreciated. We have decided to stay with the rig we have now.... for now. Thanks again
Old 11-09-2017, 08:32 AM   #17
That's probably your towing capacity. If you look at your cargo capacity numbers, you will probably find your pin weight is too heavy.
Old 11-09-2017, 09:29 AM   #18
The towing planner application was a great help to me in planning my fifth wheel/truck combination. Here's a link:
Towing Planner - towing capability calculators
Bob & Barbara Hughes
Plano, Texas
2018 Cedar Creek Silverback 33IK
2017 RAM 3500 SRW
Bob_Sback is offline   Reply With Quote
Old 11-09-2017, 01:19 PM   #19
What a truck will pull and what it is rated to pull are two different animals.
Your rating is also dependent on what you licensed your truck at. Depending on the state you live in, many people will down rate their truck to save on licensing fees.
The only way to verify you are within your limits is to weigh your rig.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
Wilco is offline   Reply With Quote
Old 11-09-2017, 01:21 PM   #20
17,000 if I go to "Capacity".
truck, weight
