Old 11-20-2014, 10:42 PM   #21
mud yapster's Avatar
I'm glad to hear the people with West Lake tires that they are performing well. Thanks for your feed back I have yet to find one person with West Lake ST tire failure.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-23-2014, 04:52 PM   #22
We were at a dealership yesterday looking at Cedar Creeks. If the coach was on the lot for a little while they had Goodyear tires.. The newest arrivals had Westlake G rated.
The one page flyer for the 2015's now show 7000 lbs axles on the 34rl and all sizes show 16" G-rated tires. Where as the previous brochure shied 6000 lb axles on the 34 rl and the 7000 lb as an option. The 7000 lb coaches used to show Goodyear LT 235/85 R16/G tires.
2 for the road is offline   Reply With Quote
Old 01-20-2015, 06:45 PM   #23
5verdriver's Avatar
Originally Posted by jimmac28 View Post
Well here's an article that will not make you feel any better about West Lake Tires.
4 Tire Companies to Avoid - CarsDirect
It ALL boils down to personal experience. Goodyear Marathons are made in China too, and I had $1800 worth of damage done to my pickup with brand new Cooper Discoveries a couple years ago due to thread separation. Both of these companies were suggested by CarsDirect. And I don't even think Cooper makes ST tires....do they? I'll keep my WestLakes.
2013 Palomino Sabre 36 QBOK-7
2012 Ford F-350 SRW 6.7 CrewCab ShortBed
PullRite SuperSlide 18k IS Rails
2006 HarleyDavidson RoadKing Classic
5verdriver is offline   Reply With Quote
Old 01-20-2015, 07:51 PM   #24
Rrickim63's Avatar
I have had good luck with Carlisle
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 01-20-2015, 08:08 PM   #25
Sign on trailers at RV Show! Youroo!!
Old 02-05-2015, 02:05 PM   #26
Phat Phrogs Incognito...
DutchF's Avatar
Too funny...
Anyway... See my sig. We've now got about 10k miles on our Westlakes. 7K axles, with Westlake ST235 80R 16, I am very diligent about the pressure and it stays at 80 psi (cold) and also us an IR temp gun to check both the truck and trailer tires, axle hubs, brakes and rear diff temps when travelling. I usually check temps, check trailer psi, truck oil / coolant and a lights visual while fueling up. Never a problem. Always have peace of mind. Just sayin'.
This last trip was about 6K miles and we did notice more than normal wear on the trailer's front right tire, on the outer edge. I'll be pulling the wheels to clean, inspect, repack bearing and replace seals along with inspecting and adjusting the brakes and inspecting and tightening the suspension.
So far the Westlakes have been fine and I will probably replace the worn tire with another Westlake (found them for about $150 online), but I need to identify and correct the cause of the wear.
FWIW, the trailer was mfg'd 7/12/13, the showroom (indoors) and at two loval RV shows unit. The tires were mfg'd first week of April, 2013 (stamped 1413). We bought it in November of 2013. We've got 168 nights camping and about 10K miles on it. I perform ALL maintenance and repairs on everything (bikes, motorcycles, truck and trailer) because I can and I trust my work. The end result is that we are quite happy with it.
Cheers!
Tina + Dutch and Bell, Bobo, Harley, Buddy (the dogs)
2011 F350 Lariat 4x4 DRW SuperCrew 6.7L (B&W setup w/Air Lift 5000 Ultimate)
2014 Columbus 365RL (Airflex and Voyager package)
Nights Camped 2014 - 154, 2015 - 32, 2016 - 4
DutchF is offline   Reply With Quote
Old 02-05-2015, 02:37 PM   #27
West Lake Tires
I would email the FR rep back and ask for a detailed answer knowing full well Good year has not changed the tire. It boils down to cost. GY 614 are very expensive and I suspect there cost went down by half to change over.
My rep made a point of saying the SB. did not come with China made tires. I think the rep said what he said to put to rest any resistance to them putting an inferior tire on the coach compared to the GY 614.
I need to clarify my above statement. My position is the GY 614 is a better tire by far over the lake tire. My intent was not to offend with my "inferior" wording. The 614 is the best trailer tire for RV's of this size but one pays for this quality compared to the other tires available.
SKGCRD is offline   Reply With Quote
Old 02-05-2015, 06:57 PM   #28
I just brought a C/C 32RL that came with Goodyear G614, it's a 2015
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 02-05-2015, 09:27 PM   #29
Update, From O P
Just got back from the 4200 mile trip so that makes about 6000 miles total on these West Lake tires. I had absolutely no problem with my tires (are anything else for that mater). I kept a close eye on them with IR gun and tire gauge most every day. 110 psi never lost as much as a pound the whole trip. Tires look to have worn very even with no abnormality at all. I feel much better about the West Lake tires. I will continue to be Leary and watch closely but I am not so sure China isn't finally getting this Mfg. thing figured out. I know some will never accept this but most of you are old enough to remember (Made In Japan) was the joke we used to say. Now look at the products coming out of their.
I hope this post doesn't come back to haunt me but for now I am satisfied with my China Tires........
rvgwen is offline   Reply With Quote
Old 02-05-2015, 09:41 PM   #30
Ret E-9 Anchor-clanker
donanddona's Avatar
I found a bad wear pattern on my left front 5r. Tire shop service manger says once a wear pattern is made you never get out of it. Mine was from backing into a concrete pad, so the service manager says. I'm glad I caught it when I did. whew! My bearings and seals checked out good. Changed the tire to new and never had that problem again.
donanddona is offline   Reply With Quote
tire, tires
