Old 10-23-2015, 09:55 AM   #1
Wet Wall Behind Mattress
We have a 2014 Cedar Creek 32RL. This morning I was changing sheets on the bed and noticed that the sheet that had been on the bed was wet around the edge. I discovered that the slide out wall behind the mattress was wet. It has not rained in several days, there is no window on that wall. What could be causing this? How do we fix it?
Thank you.
Bbbarker194 is offline   Reply With Quote
Old 10-23-2015, 10:03 AM   #2
How cold is it were you are. I have had it were the mattress is touching the wall it will insulate it, from the inside air, so it gets cold and then you can get condensation on the the wall.
Ontario
Current: 2019 Sunseeker 2290S
Happy Vibe is offline   Reply With Quote
Old 10-23-2015, 10:08 AM   #3
Islander's Avatar
In a word 'condensation' .
It is amazing how much us humans exhale 'condensation'
during our sleep.
It will condense on the cold surfaces and being that the slide wall is not exposed to any 'air movement' (trapped by the mattress and sheet) it would collect there.
If possible place something between the mattress and wall to hold it away from that cold surface....something like 2 shallow plastic containers ...not cardboard.
Only need a couple of inches to allow for air movement.
Also... crack a vent ...this will help also.
Hope this helps
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 10-23-2015, 10:44 AM   #4
Canadiancrew's Avatar
Yea if it's cold where you are its condensation. We try to leave our mattress an inch or so out from the wall. The wall stays warm and does not condense as bad.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 10-23-2015, 11:10 AM   #5
jackandjoanne's Avatar
I run a small dehumidifier especially when running the propane furnace on a cold day. Had the same issue
jackandjoanne is offline   Reply With Quote
Old 10-23-2015, 11:19 AM   #6
Flybob's Avatar
Go to dollar store and buy a couple of "pool noodles" ( $1 each). These will keep the mattress away from the wall and allow air to circulate.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Flybob is online now   Reply With Quote
Old 10-23-2015, 11:21 AM   #7
Yep, condensation. We run a dehumidifier. Surprising how much water is collected in a single night.
[SIGPIC]
2015 Palomino Columbus F375RL
2014 GMC Denali HD
6.6 turbo diesel 6-speed Allison transmission
jman63 is offline   Reply With Quote
Old 10-23-2015, 11:32 AM   #8
Pool Noodles !!! Brilliant. I have never thought of that, will have to get some next season. We too have had the condensation problem.
Russ
RussPastuch is offline   Reply With Quote
Old 10-23-2015, 01:52 PM   #9
Thanks everyone - I am off to find pool noodles!
Old 10-23-2015, 01:54 PM   #10
x99 on condensation. If it is cold enough, the condensation will frost and even freeze..
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
