Old 05-14-2015, 10:17 AM   #11
RETCHIEF's Avatar
I see what you are dealing with. I'm tall and still have a hard time seeing which is which. I keep a flashlight by the panel. I have had my TT for almost a year and still haven't memorized the switches. Hope you find a solution.
Stu and Debbie
USAF CMSgt (RET)
2014 FR Super lite 27
2015 Ram Big Horn
RETCHIEF is offline   Reply With Quote
Old 05-14-2015, 11:05 AM   #12
What about something like this? It's battery operated and turns on by touching it.
Set of 3 Gemini Stick-on Warm White LED Battery Touch Lights - - Amazon.com
Iwritecode is offline   Reply With Quote
Old 05-14-2015, 12:30 PM   #13
Chuck.C's Avatar
I have kinda the same problem with my coach. Fortunately, there is a coach battery cutoff switch by the entry. I always leave some interior lights on, and switch this off as I leave. Not only solves the entry problem, but also makes sure I don't have anything running down the batteries in storage.
Chuck.C is offline   Reply With Quote
Old 05-14-2015, 12:39 PM   #14
Boss Ox & Drovergirl
oxcamper's Avatar
Originally Posted by HeyJude View Post
I'm talking about a bank of switches just inside the door. It is a black background with black switches. I have to use a flashlight and stool to see them. DH is going to install a 12v strip light and connect it to the main rocker switch.
How about "super glueing" some sort of bead or node to the rocker switch, like braille, you can find it just by touch.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 05-14-2015, 01:05 PM   #15
I have the same unit and I just keep a small flashlight on the bottom shelf.
offduty11 is offline   Reply With Quote
Old 05-14-2015, 03:37 PM   #16
FloridaCouple's Avatar
I have the same problem and use a flashlight. Even with lights on in The Roo I cannot read the switch labels.
FloridaCouple is offline   Reply With Quote
Old 05-14-2015, 03:55 PM   #17
Wish my panel was mounted higher. I was doing some work in the new camper when my wife let our 3 yr old grandson in for the first time to see what grampa was doing. Within 10 seconds he'd flipped every switch and was working on putting in the slides.
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 05-14-2015, 04:06 PM   #18
X2, good idea.
1 bead, 2 beads or 3 if you have multiple lights and multiple switches.
Old 05-14-2015, 04:26 PM   #19
D_B Travelers's Avatar
HeyJude, we had a similar issue with our panel as it was all black and black switches; and my wife also doesn't have to duck when going through doorways. I happen to own a P-touch machine, so I printed some white background labels with bigger print and stuck them to the panel where it would be easier to see. Yes, you will learn by second nature very quickly, but a white stick on label with big printing that you can remove later, will help for now.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 05-14-2015, 05:15 PM   #20
RETCHIEF's Avatar
I did a label to warn about closing doors before slide operation, for the microwave stove vent flap, and the unmarked porch light. P-touch is great.
Stu and Debbie
USAF CMSgt (RET)
2015 Ram Big Horn
light
