Old 05-02-2015, 01:33 PM   #1
Wheel bearing
2009 Cedar Creek 36ckts has a bad wheel bearing, there are lots of posts about the SBS bearings and Libert replacing the axle because the bearings are no longer made. The posts were old and I am wondering what the status of getting bearings is currently. Does Libert still ship replacement axles or hubs for free?? I can not believe the isn't a company that doesn't make the bearings anymore. Any information would be appreciated
denville is offline   Reply With Quote
Old 05-02-2015, 01:44 PM   #2
Brother Les's Avatar
You are way out of warranty and Lippert will not replace anything for free. Had two wheel bearings go out and destroyed one axle and Lippert and Forest River would do nothing. Is the spindle on your axle ok? If it is, you can get/order and pay for a new hub and bearings. Call Lippert about your axle size (there is a sticker on the axle) and they should be able to get to you what you need (you pay...).
Brother Les
Old 05-02-2015, 04:01 PM   #3
Hi here is a resent post that has some information on the sealed bearings. Lippert LCI/SBS Sealed Bearing Update Question
Hope this helps Tim
TimVWulp is offline   Reply With Quote
wheel
