Old 01-09-2019, 08:24 PM   #1
Wheel Bearing Issues / Disc Brakes
We have a 2016 Cedar Creek 34RL. GVWR on our unit is 16,000 lbs. CAT scale shows we are at 14,800 when we travel. We added Kodiak disc brakes with new bearings in May 2017.
After putting 6000 miles on the trailer in 2017, when doing maintenance (inspecting and repacking bearings) it was discovered that the bearings were scorched. These bearings were of Chinese manufacture. The installer stood behind their work and paid for new Timken bearings.
When I discussed this recently with the installer he mentioned that they are now using Timken bearings on new installations, but he had not heard of problems with other bearings on other disc brake installations that they have done and they do many.
We used the trailer for 6000 miles in 2018. Again when doing maintenance it was found that the new bearings were scorched and also very loose. I had watched the installation of these bearings and it appeared they were installed, lubed and tightened correctly. We have verified the correct part numbers were used for the bearings and races.
Has anyone else had any of these problems either with or without disc brakes? Any idea what could have caused this to have happened twice? We are at a loss of how to proceed since this has happened twice now. Something else must be going on…?
2016 CC 34RL
2015 Silverado 3500HD DRW Diesel CrewCab Longbed
tomherb is offline   Reply With Quote
Old 01-10-2019, 10:13 AM   #2
Head Rambler
When you first installed the disc brakes, were the original bearings damaged?
Were all the bearings damaged or just some of them?
Did the installer check the hub and axle bearing surfaces with a caliper when they replaced the bearings? I would suspect the hubs more than the axles. If they didn't, it would be time to make sure they are within tolerance. They should also be checked for Out of Round.
Which grease was used in them?
Was the same brand/type of grease used both times?
Gotta go campin!
Old 01-10-2019, 10:46 AM   #3
Any chance of a photo?
I'd like to see what you are calling 'scorched.'
Maybe the incorrect grease is being used?
Days Camped: '16=46 '17=30 '18=51 '19=18
Old 01-10-2019, 11:09 AM   #4
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Whenever I do new bearings and races, I will recheck them with a ‘wiggle the wheels’ check after 1020 miles or so. Assures me the races got fully seated.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
A Loving wife
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 01-10-2019, 11:28 AM   #5
clr
When I had my trailer brakes replaced with disk brakes by Performance trailer braking the races for the bearings were already installed in the new hubs. So the races are almost always not the problem with new disk brake installations. I used grease that was recommended by Dexter axle the maker of my axles, Lucas red and tackey. I picture would really help here.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 01-10-2019, 11:48 AM   #6
Iwannacamp's Avatar
IMO...if you had 2 sets of bearings "fail"...IE 4 pairs of bearings fail. You have something miss-matched or something wrong... as in incorrect hub spacing or shaft length or something.
2017 Puma 297RLSS
Old 01-10-2019, 12:15 PM   #7
Brother Les's Avatar
...scorched...?
wrong grease?
Brother Les
Old 01-10-2019, 01:40 PM   #8
Is it possible the brakes are overheating the hubs causing failure. Even with discs, Tow vehicle must do the bulk of holding the trailer on a downgrade. No way brakes even discs can handle that energy.
Harkerr is offline   Reply With Quote
Old 01-10-2019, 02:07 PM   #9
If it were a hub, spindle, issue these parts would be discolored also. Rotors or the other brake parts would also show signs of excessive heat if there was an issue with them. It's either a lube issue, or adjustment issue. As said several time, pictures are worth a thousand words.
ard58 is offline   Reply With Quote
Old 01-10-2019, 02:09 PM   #10
D W
D W's Avatar
If by "scorched" you mean bluish-black traces, that is a lubrication problem compounded by a speed/load factor. Two different sets of bearing, two failures is not a coincidence. If you take pictures of the Timkens that failed and sent them to Timken, I'd bet they'd tell you the same thing.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
brakes, wheel
