Old 11-11-2014, 07:15 PM   #1
Wheel Rim bolt pattern
On a recent trip, I lost the spare tire for my 28 ft, 2003 Cedar Creek 5th wheel. The tires are LT235/85R-16 with a 6 lug bolt pattern. When I try to order a new rim, I am asked for the bolt pattern in a 6-XXXmm size. How do I determine this additional mm size for the rim without having to take a tire off and carrying it to the tire shop? Is there a shop in Texas which sells used trailer tire rims?
Walton is offline   Reply With Quote
Old 11-11-2014, 07:52 PM   #2
You could call Cedar Creek and ask...
This might also help.
How to Measure Bolt Patterns on Wheels of Cars: Lug Nuts (Photos)
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 11-11-2014, 08:07 PM   #3
caper's Avatar
How To Measure Bolt Patterns
Item #: Bolt_Patterns
The bolt pattern is merely the number of bolts on the wheel. As the bolts will be evenly spaced, the number determines the bolt pattern. The bolt circle is the circle determined by the positions of the bolts; the center of every bolt lies on the circumference of the bolt circle.
The important measurement is the "pitch circle diameter" (PCD), usually expressed in millimeters, although inches are often used. For a 4- or 6-bolt car, this measurement is merely the distance between the center of two diametrically opposite bolts.
If your wheel has a 5-bolt pattern, measure from the BACK of one bolt hole to the center of the second bolt hole as shown in the diagram. You can also measure from the CENTER of one bolt hole to the CENTER of the third hole using a multiplier of 1.05 to find your bolt circle.
A wheel with a 5 bolt pattern that has a pitch circle diameter of 4 1/2" will be defined as being a 5 on 4.5"
Hope this helps you with the measurements.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
wheel
