Old 06-18-2019, 04:22 AM   #1
Global Nomad
Scheinin's Avatar
Wheel Torque
I had to replace the wheel on my 36CKTS. Does any owner of a 36CKTS know what I should torc the wheel too?
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is offline   Reply With Quote
Old 06-18-2019, 04:27 AM   #2
Tech740's Avatar
If they are 1/2" studs they are 90-110 ft/lbs if I remember correctly. My trailer has that size stud and has a sticker that says 100.
2019 Ram 3500
H.O. Cummins 1,00lb/ft Aisin Trans
Andersen Ultimate 5th Wheel Connection
2019 Sandpiper FLOK
Tech740 is offline   Reply With Quote
Old 06-19-2019, 07:47 AM   #3
Stevemc's Avatar
My 2013 36ckts has 9/16" studs and I torque them at 100 lbs.
Steve & Jean
Furbaby - T.J. RIP
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
Stevemc is offline   Reply With Quote
Old 06-19-2019, 08:06 AM   #4
Chuck_S's Avatar
Note the difference in steel vs alloy wheels. 1/2" lug is likely. Regardless retorque every 50 miles until the nuts stop turning. What you did, or were supposed to do, when the trailer was new as these loosen in use until all bolt stretch is complete.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 06-19-2019, 03:53 PM   #5
Global Nomad
Scheinin's Avatar
Thank you. My wrench only goes to 80 lbs, I will get another one.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 06-19-2019, 04:20 PM   #6
Stevemc's Avatar
I probably need to revisit this. According to Chucks chart I should be torquing at 120-140. I think I've used 100 lbs because when I originally researched it I assumed my wheel studs were 1/2". I replaced all the lug nuts this summer and discovered mine are 9/16". I check them periodically and haven't had any issues but it looks like I need to be torquing at 130.
Steve & Jean
Furbaby - T.J. RIP
Old 06-21-2019, 05:55 AM   #7
I just had the same issue on the same model of trailer. The tire company that replaced my wheels advised me the torque was 160 with 80 psi air pressure.
roddiemacdonald is offline   Reply With Quote
Old 06-21-2019, 07:10 AM   #8
Canadian Member
When I had my tires replaced last week on my Rockwood 5er the tire tech insisted they should be torqued to 120 ft-lbs. If they were supposed to be torqued to 100 ft-lbs, are the studs already stretched or can I loosen them and re-torque them to 100 ft-lbs? The factory sticker says they torqued them to 100 ft-lbs.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
wheel
