Old 07-06-2013, 02:03 PM   #1
Where is CABLE hookup in Living Room on 36CKTS?
The TV connections are poorly labeled. Looking for the cable jack on 36CKTS living room. Only open connection is on Winegarde Antenna panel labeled AUX/Sat. Is this the connection from Cable input on outside panel? If not where is it hiding?
Thanks,
Jim
UncleFudd is offline   Reply With Quote
Old 07-06-2013, 02:35 PM   #2
Road-King's Avatar
If your Winegard panel looks like this one, it also has a built in coax A/B selection switch. Hook up the CATV to the outside jack on the camper, then turn "OFF" the winegard amplifier switch (LED light out), set your TV to CATV and then scan for channels...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 07-06-2013, 04:13 PM   #3
Former Full Timer
Duckogram's Avatar
In the 2012 it is in the cabinet to the right of the fireplace. You should find 3 boxes
on the back wall. Left box is a duplex 110v outlet. Center box is the amplifier. The top coax connector on the center box is aux/sat for a second connection. The lower coax connector is your antenna/cable that should already be connected to your TV. The small black button switches the amp on( green light) off (no light). The 3rd box is for a satellite box. There is also a connection for your rooftop dish located in the top of your hamper along with a duplex outlet. Hope this helps.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 07-06-2013, 04:41 PM   #4
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
Same description applies to the early 2013 model as well.
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 07-06-2013, 05:15 PM   #5
OL Creeker's Avatar
It is for reasons like that, that I'm glad we purchased from Lazy Days. When we get our CC, we'll camp there for a couple days, getting all the bugs worked out.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 07-06-2013, 08:41 PM   #6
I have a 30RL and I can not get cable, I must be doing something wrong. I can get my Tailgatter to work but can not get cable but camper is going back to Tom Johnson next week
spock123 is offline   Reply With Quote
Old 07-07-2013, 06:54 PM   #7
Cable TV when connected to the outside "Cable/Aux" input will come through on the Antenna/Cable connection when the Antenna Amplifier is OFF. (No Green Light).
However check your cable colors - Ours was wired backwards between the Sat and Cable connections - I took the plates off and reviewed the wire colors to verify which connection went to which plate.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
