Old 01-13-2019, 05:57 PM   #1
Where is the refrigerator plugged into?
I have a 2015 Cedar Creek 36 ckts with a full size whirlpool refrigerator. I am trying to locate where it is plugged into for power. Anyone know??
Norcaltom is offline   Reply With Quote
Old 01-13-2019, 06:08 PM   #2
keith52's Avatar
The wall behind the fridge
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
keith52 is offline   Reply With Quote
Old 01-13-2019, 06:23 PM   #3
Dave...Northern Nevada
2018 Rockwood 8299bs
2007 GMC 2500HD SLT short bed w/gravity flow Fuel Tank
Firestone Airbag Ride Rite system
paverdave is offline   Reply With Quote
Old 01-13-2019, 07:23 PM   #4
western NC mountains!
formerFR's Avatar
why? does it not have power?
formerFR is offline   Reply With Quote
Old 01-14-2019, 12:43 AM   #5
Probably behind the fridge but that is not easy to get to and you should not need to get to it unless you are removing the unit.
Do you have a power issue? Fridge runs off 120vac from shore power or if not connected to shore power it is supplied 120vac via an inverter. Are you having problems with the fridge not coming on?
2016 Siverback 33IK
Old 01-14-2019, 10:07 AM   #6
Jim34RL's Avatar
If you need access to the electrical cord behind the fridge, it is very easy to access.
First step is too removed the wooden board under the fridge that is blocking the wheels. The second step is too unfasten the two hold down brackets on top of the fridge. These are screwed into the spacer boards that are part of the trim. Then simply roll the fridge straight out from the wall. You can access the electrical cord and the water line from the rear now.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 01-14-2019, 09:44 PM   #7
Happy Camper
The outside lower cooling vent is easy to remove and may uncover electrical connections as well as LP gas fittings.
Johntgif is offline   Reply With Quote
Old 01-14-2019, 09:56 PM   #8
Global Nomad
Scheinin's Avatar
The original poster as a residential refrigerator in a 36CKTS, there is no LP gas fittings.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is offline   Reply With Quote
Old 01-14-2019, 10:02 PM   #9
It's a dedicated line that goes to the inverter. On mine, the inverter is plugged into receptacle in the front left corner of the RV. That receptacle gets its power from the same breaker that feeds the washer receptacle. If you lose AC power or disconnect from AC power, the inverter produces the AC power to feed your refrigerator. Of course, the inverter gets its power from your battery bank.
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
refrigerator
