Heat pads are the far right rocker switch on the panel. BIG red light above it. Toggles on and off.
Did you fill the Fresh Water Tank? You have to turn the toggle switch in outside compartment away from City and towards Gravity, then let the water fill up the FWT. It will overflow under trailer if you fill too far.
THEN turn on pump inside. Should be the toggle switch to the LEFT of the DSI/FLT switch. Then turn on water faucet.
FROG AR-0019-242
